Marcarl Posted February 16, 2012 Share #1 Posted February 16, 2012 (edited) I think I finally got it altogether. What you'll get: 2 side covers,laser cut, mirror stainless 1 stainless bracket for left side 2 spacers glued to the back of the right side cover 4 stainless screws to attach the covers (metric) 2 replacement bolts to attach the left side bracket 2 washers for the above bolts 2 spacers for the above bolts 1 banjo bolt, if you need to replace the one sticking out from the rear brake master. 2 crush washers for above banjo bolt. Instructions: On the left side you need to remove the 2 bolts on top of the middle gear. You can store these for another purpose. Install the 2 new bolts from the package with the bracket as shown. Spacers go down first, then the bracket, facing out, and the the supplied washers and bolts. Torque to 17 ft lbs. On the right side you might need to remove the banjo bolt that is facing the outside from the rear master cylinder and replace it with the thinner headed banjo supplied. The supplied crush washers are also thinner, so use all supplied components. This is necessary as the OEM banjo sticks out too far to make a nice flat installation. You will need to bleed the rear brakes again, so before tightening the banjo, pump a bit of fluid through the joint to eliminate as much air as possible. Total cost will be $150 or less, including shipping. Please indicate if you want to join in the party. Once I have a count, I can then get a firm price for the stainless, let you know the actual cost and get your money before we make them. This will be a one time only deal. Sorry about the dirty scoot, I've been too busy trying to put this together to worry much about it. Edited March 27, 2012 by Marcarl Link to comment Share on other sites More sharing options...
bkuhr Posted February 16, 2012 Share #2 Posted February 16, 2012 Afraid to ask, because then I may want one, but do you have any pics of the kit installed? What years designed to fit? Link to comment Share on other sites More sharing options...
Marcarl Posted February 16, 2012 Author Share #3 Posted February 16, 2012 Afraid to ask, because then I may want one, but do you have any pics of the kit installed? What years designed to fit? Added some pictures to the first post for you. Maybe it would look better cleaned up though. Link to comment Share on other sites More sharing options...
tufftom4 Posted February 16, 2012 Share #4 Posted February 16, 2012 Count me in. Tom Link to comment Share on other sites More sharing options...
Wizard765 Posted February 16, 2012 Share #5 Posted February 16, 2012 Carl: You could have at least washed your scoot first... or put them on mine Link to comment Share on other sites More sharing options...
dingy Posted February 16, 2012 Share #6 Posted February 16, 2012 Here are a couple of other shots of the original version of Carl's plates. Will look identical to these. Gary Link to comment Share on other sites More sharing options...
dingy Posted February 16, 2012 Share #7 Posted February 16, 2012 Carl: You could have at least washed your scoot first... or put them on mine That's one of the better reason's to own a 1st gen, they are ridin' machines, not washin' machines !! Gary Link to comment Share on other sites More sharing options...
Marcarl Posted February 17, 2012 Author Share #8 Posted February 17, 2012 That's one of the better reason's to own a 1st gen, they are ridin' machines, not washin' machines !! Gary Thanks Gary,,, I wouldn't of thought of that reply,,, but it's good!!!:happy65: Link to comment Share on other sites More sharing options...
cabreco Posted February 17, 2012 Share #9 Posted February 17, 2012 Oh WOW I was wondering what these pieces were for. I found these in a box of parts that came with my parts bike. COOL! Link to comment Share on other sites More sharing options...
Midicat Posted February 17, 2012 Share #10 Posted February 17, 2012 I'm definitely in!! Mark me down for a set. Thomas Link to comment Share on other sites More sharing options...
Marcarl Posted February 19, 2012 Author Share #11 Posted February 19, 2012 bump Link to comment Share on other sites More sharing options...
friesman Posted February 19, 2012 Share #12 Posted February 19, 2012 I like the look, they really finish off the side view of the bike. Brian Link to comment Share on other sites More sharing options...
Jayceesfolly Posted February 20, 2012 Share #13 Posted February 20, 2012 They look good to me, put me in for a set. Thanks Jim Link to comment Share on other sites More sharing options...
Marcarl Posted February 22, 2012 Author Share #14 Posted February 22, 2012 bump Link to comment Share on other sites More sharing options...
Wizard765 Posted February 22, 2012 Share #15 Posted February 22, 2012 Oh YEAH!!! better than chrome.... I want a set for sure... :cool10: Link to comment Share on other sites More sharing options...
Evan Posted February 23, 2012 Share #16 Posted February 23, 2012 Carl, been off the site for a while so just now seeing this. Guess I got lucky as my VR had these chrome covers on it when I bought it. Link to comment Share on other sites More sharing options...
calgaryrider Posted February 23, 2012 Share #17 Posted February 23, 2012 I'm really not a big fan of chrome but I do need the screws, could you tell me the size and pitch they are? Thanks Markus Link to comment Share on other sites More sharing options...
Marcarl Posted February 23, 2012 Author Share #18 Posted February 23, 2012 I'm really not a big fan of chrome but I do need the screws, could you tell me the size and pitch they are? Thanks Markus Yep. no problem. Link to comment Share on other sites More sharing options...
Marcarl Posted February 23, 2012 Author Share #19 Posted February 23, 2012 I'm really not a big fan of chrome but I do need the screws, could you tell me the size and pitch they are? Thanks Markus Oh my!!! you wanted to know right away???? sure: M5x16x1.25, although some applications may need to have them 20mm long. Link to comment Share on other sites More sharing options...
bongobobny Posted February 26, 2012 Share #20 Posted February 26, 2012 OK Carl, sign me up for a set... Link to comment Share on other sites More sharing options...
Marcarl Posted February 27, 2012 Author Share #21 Posted February 27, 2012 Ok so far I've got: Tufftom4 Wizard765 Midicat Jayceesfolly Bongobobny Link to comment Share on other sites More sharing options...
Midicat Posted March 24, 2012 Share #22 Posted March 24, 2012 so? Link to comment Share on other sites More sharing options...
Marcarl Posted March 24, 2012 Author Share #23 Posted March 24, 2012 so? It's all together,,, almost, just waiting for Bob to deliver the banjo bolts today. Then all will be ready for pick up or shipping. I just need to get the final price yet for the stainless. I had 10 sets made, so I'm not sure what the discounted price is.. Link to comment Share on other sites More sharing options...
Wizard765 Posted March 24, 2012 Share #24 Posted March 24, 2012 Almost there.. I think we are just waiting for one more small part to make it work slick... There is a test set on MY scoot right now.. They look GREAT!! I think Bob is bringing a bag of those parts to the M&E tonight... Link to comment Share on other sites More sharing options...
Marcarl Posted March 27, 2012 Author Share #25 Posted March 27, 2012 Alright,,, got it all together,, boy,, that took a while, had to get parts from all over North America. Total cost is $140 including shipping, so if you pick it up or get delivery some other way, you may take off the $25.00 shipping cost, for a cost of $115.00. When you pay, Paypal, (cnorg (at)silomail.com) please send me a PM with your address so that I can ship a set to you. Thanks Carl Link to comment Share on other sites More sharing options...
