Prairiehammer Posted February 24, 2012 Share #101 Posted February 24, 2012 A guy here: http://goldwingtech.info/exavid/forktool.html made a simple tool to help install the cap. Link to comment Share on other sites More sharing options...
KIC Posted February 24, 2012 Author Share #102 Posted February 24, 2012 Cool tool. My forks are on the bike so that wouldn't work for me now. I gotta figure out how to get it together while on the bike. Link to comment Share on other sites More sharing options...
Prairiehammer Posted February 24, 2012 Share #103 Posted February 24, 2012 Perhaps the same idea but instead of clamping to the tube, rig up something to slip under the upper triple tree? Link to comment Share on other sites More sharing options...
Snaggletooth Posted February 24, 2012 Share #104 Posted February 24, 2012 KIC, Just guessing here as I'm just getting started on my '87 fork rebuild and haven't checked the Progressives fit in it yet but.... Using both the PVC spacer AND the top cup off the old top steel spacer looks like it is doubling the preload. All you really need is the flanged washer on top of the spring and the spacer on top of that. It should be close to even with the top of the fork. As you thread the top cap in it will compress the spring about 3/4 of an inch as it goes in. The top cup (with the o-ring) might even be enough to fit right instead of the PVC. It looks to be about the same size. See how that lines up. Mike Link to comment Share on other sites More sharing options...
KIC Posted February 24, 2012 Author Share #105 Posted February 24, 2012 KIC, Just guessing here as I'm just getting started on my '87 fork rebuild and haven't checked the Progressives fit in it yet but.... Using both the PVC spacer AND the top cup off the old top steel spacer looks like it is doubling the preload. All you really need is the flanged washer on top of the spring and the spacer on top of that. It should be close to even with the top of the fork. As you thread the top cap in it will compress the spring about 3/4 of an inch as it goes in. The top cup (with the o-ring) might even be enough to fit right instead of the PVC. It looks to be about the same size. See how that lines up. Mike That's what I am thinking, but the cup has the o-ring on it and I presume that is there for a reason. I can not find any pictures or info on exactly the line up of parts. So close and yet ( again) so far... Good luck on your rebuild. if it's your first time an you want to discuss it, call me...I can tell you all the things I did wrong so you can do them correctly Link to comment Share on other sites More sharing options...
Snaggletooth Posted February 24, 2012 Share #106 Posted February 24, 2012 First rebuild? Who ya talking to KIC? This is my forth set. Did two on the '84 forks and started on a set of '87's for my R1 upgrade but gave up after finding SO MUCH internal damage by the PO. Just got another set of '87's a while back and starting on polishing them up before this rebuild. That top cup with the o-ring appears to do nothing more than center that long OEM steel spacer inside the upper tube. You wanna talk about screwed up stuff I could tell ya about some of the cobble jobs I have picked up off fleaBay. Water pipe spacers two different sizes, lock washers on the oil locks, chisel goughs where the seal was cut out of the tubes, missing or wrong rebound springs, ah heck. Some creative minds out there and some are downright dangerous with tools. These new '87's I got had ALL the wave washers on one side and nuttin on the other. Haven't even got the oil locks out yet of these. Wedged in pretty tight. That's tonights project. Heat gun and some dry ice to shock 'em out. Maybe. You my friend had it easy. It could have been a lot worse. But check those measurments and see how close that spacer comes to the top. Mike Link to comment Share on other sites More sharing options...
KIC Posted February 24, 2012 Author Share #107 Posted February 24, 2012 First rebuild? Who ya talking to KIC? This is my forth set. Did two on the '84 forks and started on a set of '87's for my R1 upgrade but gave up after finding SO MUCH internal damage by the PO. Just got another set of '87's a while back and starting on polishing them up before this rebuild. That top cup with the o-ring appears to do nothing more than center that long OEM steel spacer inside the upper tube. You wanna talk about screwed up stuff I could tell ya about some of the cobble jobs I have picked up off fleaBay. Water pipe spacers two different sizes, lock washers on the oil locks, chisel goughs where the seal was cut out of the tubes, missing or wrong rebound springs, ah heck. Some creative minds out there and some are downright dangerous with tools. These new '87's I got had ALL the wave washers on one side and nuttin on the other. Haven't even got the oil locks out yet of these. Wedged in pretty tight. That's tonights project. Heat gun and some dry ice to shock 'em out. Maybe. You my friend had it easy. It could have been a lot worse. But check those measurments and see how close that spacer comes to the top. Mike :bowdown:My apologies o-mighty experienced one. I have a set of the 3 washers if you want them. I got some from Dingy and had only damaged one wavy washer so there are 5 good ones. If you want them I can "pay them forward" to you. I know our Stealership wanted almost $10.00 per washer for them. So.. my question still stands... the top of the progressives are sitting right at the bottom of the cap threads. the PVC spacer is 3/4-inch. The cup with o-ring is 3/4 inchish which brings it to a little over 1 1/2 inches with the washer thickness.. It just seems real difficult to push down and screw the cap in without stripping the theads. Let me know on the washers.. Bill Link to comment Share on other sites More sharing options...
dingy Posted February 25, 2012 Share #108 Posted February 25, 2012 Attached are progressive instructions. Gary Link to comment Share on other sites More sharing options...
dingy Posted February 25, 2012 Share #109 Posted February 25, 2012 A few more pictures attached. Pay attention to the 9th picture. It shows 2 sets of washers that go above & below seal. The pair on the left go below the seals, the pair on the right go above seals. They have a different I.D. This is important, if the set on the right is put in first, the upper bushing can come back up through these. 10th picture show the progressive spacers & what I did with spring top washer on the spacers. I had to cut a little out of the I.D. of the PVC to get them to fit in there. 17th picture shows what seal should look like just before dust cap goes on. Last 2 show the VMax rim and FJR rotors being fitted up. Gary Link to comment Share on other sites More sharing options...
Snaggletooth Posted February 25, 2012 Share #110 Posted February 25, 2012 :bowdown:My apologies o-mighty experienced one. I have a set of the 3 washers if you want them. I got some from Dingy and had only damaged one wavy washer so there are 5 good ones. If you want them I can "pay them forward" to you. I know our Stealership wanted almost $10.00 per washer for them. So.. my question still stands... the top of the progressives are sitting right at the bottom of the cap threads. the PVC spacer is 3/4-inch. The cup with o-ring is 3/4 inchish which brings it to a little over 1 1/2 inches with the washer thickness.. It just seems real difficult to push down and screw the cap in without stripping the theads. Let me know on the washers.. Bill Thanks for the offer but I'm cool on parts. That's the thing about having done several sets.... left overs. When I'm done with this set I'll have two working set ups. The original '84's with stock brakes and the finished '87's with the R1 upgrade. Not to mention both sets fully polished. I'm still sticking with losing one of the spacers. Like in Dingys #10 pic, use the cupped washer with the PVC ONLY. The 1 1/2 inches is WAY to much. You're asking for a fight you may not win. Mike Link to comment Share on other sites More sharing options...
Snaggletooth Posted February 25, 2012 Share #111 Posted February 25, 2012 A few more pictures attached. Gary Ya know Gary ..... If they had never invented digital cameras how would you ever get out of the darkroom and find time to hang here and work on your bike? Link to comment Share on other sites More sharing options...
dingy Posted February 25, 2012 Share #112 Posted February 25, 2012 I have a complete set of front brakes for an MKII available if I get a decent price out of them. MKII calipers that have recently been rebuilt and very good rotors. Also set of anti dives. Gary http://i1007.photobucket.com/albums/af193/gdingy101/PICT5383as-1.jpg Link to comment Share on other sites More sharing options...
KIC Posted February 25, 2012 Author Share #113 Posted February 25, 2012 You know..I just finished putting the springs all together, the fork is installed and tightened up. Was going to install the front tire, but decided to wait until tomorrow so I can clean and polish a few pieces before it all goes together. Feeling pretty dang good about the progress... AND THEN YOU GO and tell me that there is a difference in the seal washers that could affect the bushing coming up.... ..... I have no freakin idea which way I put those puppies in.... Life sucks and then you die...... ugh ! Link to comment Share on other sites More sharing options...
dingy Posted February 25, 2012 Share #114 Posted February 25, 2012 Just slide your dust covers up & see if if you can see the seal lip between fork tube & washer. Look at 17th picture I posted above, Gary Link to comment Share on other sites More sharing options...
KIC Posted February 29, 2012 Author Share #115 Posted February 29, 2012 Well... It is DONE !!!! I got to ride the puppy today for 6 or so miles. The front end is so nice!!! Purposely hit speed bumps tried to dive the front forks it just all felt nice ! The progressives are great ! ( Thanks Skydoc_17) The steering is SO SO SO much nicer having cleaned and greased the steering head bearings. Also got the battery by-pass done. Did some ABS welding while it was apart, installed washers on the 16-head bolts. Tightened the (added a washer) speedo/gauge console ( no more rattle). New plugs have got to be a good thing since it seems to be running very smooth. Found a hide-a-way key, so I now have 2 keys :happy65:Don't forget the quarter I found behind the front right spark plug. AND , most of all...got the experience to install the seals on any other 1st Gen. AND..since I am driving out of town tomorrow morning to (most likely) buy a blonde 87 1st Gen that needs front seals... I won't be so intimidated and hopefully won't make the same 967 mistakes I made the first time. a special thanks to those who helped me and offered so much support and the phone calls from Rocket in an attempt to keep me sane. Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 29, 2012 Share #116 Posted February 29, 2012 Sounds like we are getting another wrench around here. (only couple miles) Every body meet at Kics house!!!:clap2: Link to comment Share on other sites More sharing options...
KIC Posted February 29, 2012 Author Share #117 Posted February 29, 2012 Only got a couple of miles because I was supposed to go out of town to pick up a blonde 87. It was postponed until tomorrow morning. If I buy this one I have to sign up for Ventureholics Anonymous. I can't become like somebody who has like 7 of them... my EXISTING garage isn't big enough for any more.... and there is no room to add on... HI...my name is KIC and I'm a Ventureholic...... Link to comment Share on other sites More sharing options...
wrenchrob Posted February 29, 2012 Share #118 Posted February 29, 2012 Congratulations KIC, I have been following your thread (your battle) since the start and got a couple of good laughs at your expense. Its got to be a good feeling now though that you have accomplished this complicated overhaul. So you must have enjoyed doing this since you are going to go buy another one and tackle it again. Hope round 2 goes better for you. I can kind of relate. Bought a 05 RSV last October that had been in a slight accident and i literally took it apart font to back and overhauled and mosified extensively. I enjoyed this winte doing that and now have recently bought a 03 that definately needs a lot of TLc. It is going to be next winters project (or sooner if wi have a rainy summer). Anyways congrats again and good luck on your next one. Rob:080402gudl_prv: Link to comment Share on other sites More sharing options...
KIC Posted February 29, 2012 Author Share #119 Posted February 29, 2012 (edited) Congratulations KIC, I have been following your thread (your battle) since the start and got a couple of good laughs at your expense. Its got to be a good feeling now though that you have accomplished this complicated overhaul. So you must have enjoyed doing this since you are going to go buy another one and tackle it again. Hope round 2 goes better for you. I can kind of relate. Bought a 05 RSV last October that had been in a slight accident and i literally took it apart font to back and overhauled and mosified extensively. I enjoyed this winte doing that and now have recently bought a 03 that definately needs a lot of TLc. It is going to be next winters project (or sooner if wi have a rainy summer). Anyways congrats again and good luck on your next one. Rob:080402gudl_prv: Thanks. We'll see how this deal on the 87 goes. leaving in an hour to go see/get the puppy. Hopefully the next time I do the forks on this one which I believe will the 432nd time I would be taking a 2nd 1st Gen's forks apart in the last 2 months, may go smoother. We will see. More entertainment to come...same time same channel... Edited February 29, 2012 by KIC Link to comment Share on other sites More sharing options...
Rocket Posted February 29, 2012 Share #120 Posted February 29, 2012 a special thanks to those who helped me and offered so much support and the phone calls from Rocket in an attempt to keep me sane. Too late, you're already a member...... But seriously, I find it quicker & easier to talk someone through things, than to type it out, unless parts diagrams are also needed. Sorry I missed your last call, phone was in the tool box & I was elsewhere in the base workshop. I heard the voicemail after reading the thread additions, that night. Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 29, 2012 Share #121 Posted February 29, 2012 Thanks. We'll see how this deal on the 87 goes. leaving in an hour to go see/get the puppy. Hopefully the next time I do the forks on this one which I believe will the 432nd time I would be taking a 2nd Gen's forks apart in the last 2 months, may go smoother. We will see. More entertainment to come...same time same channel... 2nd Gen forks?? Is there something you would like to tell us??:whistling: Link to comment Share on other sites More sharing options...
Rocket Posted February 29, 2012 Share #122 Posted February 29, 2012 Sounds like we are getting another wrench around here. (only couple miles) Every body meet at Kics house!!!:clap2: Just might, be doing more touring again this year, so this could be a possibility. Link to comment Share on other sites More sharing options...
KIC Posted February 29, 2012 Author Share #123 Posted February 29, 2012 2nd Gen forks?? Is there something you would like to tell us??:whistling: :rotf:Ok you caught me .. I'm a closet 2nd Genner... I corrected the TYPO in the original post.. Link to comment Share on other sites More sharing options...
KIC Posted March 1, 2012 Author Share #124 Posted March 1, 2012 Well.... I picked up the blonde today. Definitely needs new front seals..luckily this one came with brand new Yamaha seals and dust caps. Interesting bike....needs a little TLC in some areas but overall a well kept bike. So... the adventure starts all over again.... no wait.... Link to comment Share on other sites More sharing options...
Yammer Dan Posted March 1, 2012 Share #125 Posted March 1, 2012 Well.... I picked up the blonde today. Definitely needs new front seals..luckily this one came with brand new Yamaha seals and dust caps. Interesting bike....needs a little TLC in some areas but overall a well kept bike. So... the adventure starts all over again.... no wait.... I know where a Blonde is. In pretty good shape. Humm... Can you fit a 1st Gen in the back of a short bed Ranger?? Link to comment Share on other sites More sharing options...
