Chaharly Posted January 31, 2012 #1 Posted January 31, 2012 I have an 83 1200 and i need the complete carb rebuild kit. I'm looking for a cheap one, and hopefully someone can help. Any info would be much appreciated Thanks -CJ
utadventure Posted January 31, 2012 #2 Posted January 31, 2012 (edited) If I remember correctly, there isn't a "kit" available, you have to purchase the parts separately. Clean it well. You might not need any internal parts. Remove the diaphrams and check them for rips or pinholes. Pinholes can be fixed but tears should be replaced. There was a special price worked out for replacements. A little searching will find them on the site. http://www.venturerider.org/forum/showthread.php?t=32943 While you have it apart, you might want to adjust the needles. This can improve the fuel mileage. Again, if you needles don't have adjusters, you can change it changing the washers. There are instruction on the site also. http://www.venturerider.org/forum/showthread.php?t=28432&highlight=needle+shim Dave Edited January 31, 2012 by utadventure
Chaharly Posted January 31, 2012 Author #3 Posted January 31, 2012 utadventure said: If I remember correctly, there isn't a "kit" available, you have to purchase the parts separately. Clean it well. You might not need any internal parts. Remove the diaphrams and check them for rips or pinholes. Pinholes can be fixed but tears should be replaced. There was a special price worked out for replacements. A little searching will find them on the site. http://www.venturerider.org/forum/showthread.php?t=32943 While you have it apart, you might want to adjust the needles. This can improve the fuel mileage. Again, if you needles don't have adjusters, you can change it changing the washers. There are instruction on the site also. http://www.venturerider.org/forum/showthread.php?t=28432&highlight=needle+shim Dave Thank you very much
Cougar Posted January 31, 2012 #4 Posted January 31, 2012 http://www.randakks.com/ His stuff is the BEST, I used a kit for a 1100 and worked great tried the cheaper one's but they failed. his stiff is worth the money spent
motorcycle.jockey Posted January 31, 2012 #5 Posted January 31, 2012 I've heard that the 1200 Vmax carb rebuild kits will also work.
djh3 Posted January 31, 2012 #6 Posted January 31, 2012 Give this place a look over. When I needed some parts for my Kawai they had best prive. http://www.powersportsplus.com/
Squidley Posted February 1, 2012 #7 Posted February 1, 2012 Chaharly said: I have an 83 1200 and i need the complete carb rebuild kit. I'm looking for a cheap one, and hopefully someone can help. Any info would be much appreciated Thanks -CJ CJ, Here are the kits I purchased from this ebay seller that were just installed in my carbs I rebuilt. http://www.ebay.com/itm/Yamaha-VMX12-V-Max-Carburetor-Repair-Kits-VMX1200-VMAX-/380406812168?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D380375065642%26ps%3D63%26clkid%3D6009930292903665511
