http://www.venturerider.org/forum/showthread.php?t=16934
I also am going to add the slim Baffels
http://www.crutchfield.com/S-dZOVYAsoIP6/App/Product/Item/Main.aspx?i=237XT42
to them as well. It should help the Front speakers
a whole Lot! I am doing this today or tomorrow.
The fronts lose's way to much from the sound falling
into the fairing.
I also am still gunna add the baffles to the rear as well.
NOTE: if installing baffles make sure you cut a dime size hole into the bottom
of the baffle for the air suction.
Good Luck.
Jeff
Are they Marine?
Cause I'm looking to Up Grade mine. (Same Bike)
I can't deal with this 14 watt speakers anymore........
They are waterproof, but stay away from them they are crap.... Go with Pioneer or Polk, I had Pioneer TS-G1040R in my 03 and they sounded good but I would have to say they didn't sound any better then the stock. If you want better sound install an equalizer.
I would have to agree, I have installed the Pioneers in a couple of bikes and they are only slightly better than the stock speakers. I also bought one of the small Amp and it is totally junk, I wouldn't call it an Amp, might qualify as a resister or impedance.
I believe the people using the Equalizers are having better luck with those then what I did.
Be interested to hear what you end up with and how you like it.
Jerry
Jerry
Jerry because my bike is new (07) I'm not sure if I will install an eqalizer or not, some dealers would have a problem with the warranty. For the time being I'm going to stick with the stock until I run into another member who has upgraded and I can hear for myself.
I think it would help a bit. but if I had stock speakers and was going to go to the trouble of putting the baffles in I would change out the crappy
speakers myself. they are terrible.
my 2 Cents! :)
Jeff
Don't want crappy !! Took your advice and placed the order for the db400 with the baffles ! Enjoyed your write-up and will be referencing it when I put mine in.
Also, make sure you got the SLIM BAFFLES!
Heck you might have the baffles on before me..
My past week I have been kinda sick and
I have not had a chance to go out into the garage
yet. It also has been below ZERO the past couple days!
Yuck!
