I see that some members are adding as per instructions from the mg. of seafoam 1&1/2 oz. per qt. in with the oil to clean up the sludge in the engine. My question is do you leave the seafoam in for 5000 miles or until the oil is dirty or do you run the engine a short time and immediately remove the seafoam and oil replacing same.?? DanC :cool10:
I have used Sea Foam in my oil on my 02 Dodge Ram 1500 once a year for the last three years. The truck with the 4.7L engine has 142K on it and runs great and uses no oil. this engine has been reported as the worst engine ever for Chrysler Motors with failures at 30-60K miles. Changing the PCV valve yearly is also in the maintenance. I change the oil every 3,000 miles.
:farmer:
