Curby Posted January 29, 2012 #1 Posted January 29, 2012 I need to charge my battery for my 09 RSV. It it under the seat? I understand from a thread that there are two bolts to remove under in front. A little help please, Curby
Nighthawk II Posted January 29, 2012 #2 Posted January 29, 2012 Where the seat meets the fuel tank feel back about 3 inches under the seat and you will find two 10 mm nuts. remove them and lift the front of the seat and there you have it.
steamer Posted January 29, 2012 #3 Posted January 29, 2012 Thats right, it's under the seat. One nut under each side at the front of the seat. I don't remember what size nut.
Eck Posted January 29, 2012 #5 Posted January 29, 2012 Once you get the seat off you can cut two pieces of small rubber hose about 1.5 inches long and just slip them over the threads of the two seat bolts.. The seat isnt going anywhere.. anyway, and this eliminates the frustration of removeing those 10mm nuts everytime you want to take the seat off. You can just pull down on the rubber hosed and wha lah... Another suggestion: You may want to go to an ACE hardware store and see if you can find two 10 mm "wing nuts".. Wont need any tools to remove the seat.............
M61A1MECH Posted January 29, 2012 #6 Posted January 29, 2012 Eck, the rubber hose idea sounds good, but i would cautionn anyone that is not using a threaded fastener of some type to remember that fact if for any rason you find your self trailing your Venture. Seats that were not properly fastened down have ben known to fly off when on a trailer at highway speeds, when the third nut :whistling:is sitting on the seat that is never a problem. Just a reminder, because Ventures are so seldom on trailers it rarely comes to mind.
TARHEEL RIDER Posted January 29, 2012 #7 Posted January 29, 2012 Aother idea is to get a battery tender and run the connection through the right side cover. It is much easier to hook it up by removing on screw on the cover. Just a thought....................
awsmsrv Posted January 29, 2012 #8 Posted January 29, 2012 Aother idea is to get a battery tender and run the connection through the right side cover. It is much easier to hook it up by removing on screw on the cover. Just a thought.................... Or install a powerlet in the left panel behind the seat where there is already a (plugged) hole & then just plug your battery maintainer into that. That's what I did.
wrenchrob Posted January 29, 2012 #9 Posted January 29, 2012 I like that idea of wiring the battery tender through the 12V receptacle and it just so happens I have the bike apart reight now. Thanks for the good tip.
wes0778 Posted January 30, 2012 #10 Posted January 30, 2012 Once you get the seat off you can cut two pieces of small rubber hose about 1.5 inches long and just slip them over the threads of the two seat bolts.. The seat isnt going anywhere.. anyway, and this eliminates the frustration of removeing those 10mm nuts everytime you want to take the seat off. You can just pull down on the rubber hosed and wha lah... Another suggestion: You may want to go to an ACE hardware store and see if you can find two 10 mm "wing nuts".. Wont need any tools to remove the seat............. Just some thoughts on the wing nuts, 10mm is the size of the socket needed to remove them not the thread size. Not sure what it is. second IF you use wing nuts that are not nylon locking (if there is such an animal) I'd still use the rubber hose with the wing nuts to keep them from vibrating loose and falling off. OR there is a member(Rick Butler maybe?) on here that makes ez-on ez-off seat nuts.
steamer Posted January 30, 2012 #11 Posted January 30, 2012 I use 1/4-20 Nylon wing nuts I picked up at lowes for around $.50. Just cross thread them on the metric stud. They will not vibrate off. At that price a keep an extra set in the trunk in case I lose one.
