rstacy Posted January 25, 2012 Posted January 25, 2012 Earl put together an awesome thread for balancing your Gen 1 carbs. http://www.venturerider.org/forum/showthread.php?t=56723&referrerid=11995 With Earl's permission, I took the thread and converted it to a PDF. I also put the pictures with the appropriate text. This gives you a document that you can easily print out and follow step by step. I was able to balance my carbs in less than 30 minutes and now that I have done it once, I'm sure that I could do it in under 20 minutes. Thanks Earl! Ray
Venturous Randy Posted January 25, 2012 Posted January 25, 2012 That is really good you guys. My only suggestion would be to rotate the pictures to be orientated correctly so I don't have to set my lap top on it's side. RandyA
rstacy Posted January 25, 2012 Author Posted January 25, 2012 I don't disagree with you. I wanted to create a document that was easy to print so that I could have it laying on the garage floor as I went through the steps. With that in mind I rotated the pictures for maximum image area on the page. I thought that the screws were going to be difficult to locate. They were actually very easy to find.
Pegasus1300 Posted January 25, 2012 Posted January 25, 2012 In reading thru your writeup esp. the part about checking your Carbtune,if it is not alright what do you do,and what constitutes "not alright"? A very good and easy to follow sheet.Thanx for all your work.
skydoc_17 Posted January 27, 2012 Posted January 27, 2012 Hey Paul, Usually, if your Carbtune is not reading the same on all 4 channels, it is due to dirt or moisture on the rods. A good cleaning and you are good to go. You can do this by opening up the back. If one or more rods are "way off", then there are adjusting nuts on the bottom of each rod. I would also mention that there is a warranty on the Carbtune. It requires that you send it back for adjustment, but Morgan is happy to repair the Carbtune for you. www.morgan.com Earl
