mother Posted January 19, 2012 Posted January 19, 2012 i am looking for all the rubber brake lines for a 86 mkII. if you have upgraded to new braided lines if i could borrow your old ones and i can return them to you if you want. i have a vendor within walking distance of my house who does custom brake lines and i want to give him a try. he needs a sample set to make the new ones. let me know if you can help or pm me. thanks , Scott
dingy Posted January 19, 2012 Posted January 19, 2012 See if this helps you any. Here is a list of lines I had from my 1st gen 83 Should be same as MKII, except you don't need the anti dive valve hoses. And the MKII with upper burp valve is listed instead of the MKI. Don't have a picture of it though. Gary Rear Master to front steel line at rear master. 4 3/4" from face of 10mm fitting to C/L of banjo fitting Banjo @ 15 deg. Front metering valve. (This line is from a 1988 bike with the upper bleeder port) 8 5/16" from face of 10mm fitting at top bleeder to C/L of double banjo fitting 33 3/4" from C/L of double banjo fitting to C/L of banjo fitting at brake caliper. Bottom banjo fitting 15 deg. Front master to brake caliper 44 1/4" C/L to C/L Top fitting 45 deg. Bottom fitting 15 deg. Two banjo fittings are in line with a combined angle of 60 deg. Anti dive valve 11 1/2" C/L to C/L of banjo fittings. Top clutch line 22 1/2" C/L banjo fitting to face of 10 mm fitting Banjo fitting 15 deg. Lower Clutch line 8 1/2" C/L banjo fitting to face of 10 mm fitting
