Got to use my Christmas present for the 1st time. Borrowed a Carbon_One adapter from a member here in town.
Swapped out my rear shock this afternoon.
Haven't ridden it yet, but seems the bounce is gone.
Nope. I didn't chuckle when I saw the lead hammer. Or the skint hand... Not even a little bit..... heh heh....
BFH is always within reach
AND
Sometimes I think I'll just stab myself with a screwdriver before I even start, just to get it over with.
Walter is wondering what the lead is in the bottom right pic. (ok,ok, I was wondering too)
Brian
Not related to the shock change... but is the accessory plug under the seat by the battery on a 2nd Gen. Can be used to add accessory power (cigarette lighter) under the seat to be used for a compressor, other powered accessories (the one on the fairing only has a 5A fuse), or for a cigarette lighter. There is a hole below the seat on the left side with a rubber grommet where you can put the accessory plug.
Oh... I liked the small sledge hammer. A must have for delicate projects !
WOW!!! :shock3:
What a difference!!! Put about 50 miles on the bike this afternoon and it rides better than when I 1st got it!:bluesbrother:
Pogo Stick is GONE :cool10:
Mine made a huge difference in the ride. Which shock did you go with?
Oh it is a slightly used OEM Yammie shock, off a friend's '01(I think). Was not leaking but he chose to try a Works, so this one was just collecting dust in his shop.
Sounds good, I'm sure it was a lot cheaper than the Work's Shock. I just hope I never have to replace mine again...
