rstacy Posted January 12, 2012 #1 Posted January 12, 2012 I just finished installing a 2nd gen starter on my 1st gen 86 VR. It clearly solved the slow cranking. I cant say that I enjoyed the job. It wasn't a difficult job but you have to remove a lot of parts to get to the starter. I purchased new O-rings for the connections at the thermostat housing. Is a good idea to lube the rings with anything to help with reassembly and sealing? Maybe water soluble Vaseline or silicone?
dingy Posted January 12, 2012 #2 Posted January 12, 2012 You could just use straight anti-freeze on them. The glycol in anti freeze will act as a lubricant & then be compatible. Gary
Yamamike Posted January 12, 2012 #3 Posted January 12, 2012 Always a good idea to grease o-ring when installing...I would suggest the you use non petroleum based grease though just in case they are made of EPT. Otherwise they'll swell and could break down.
saddlebum Posted January 12, 2012 #4 Posted January 12, 2012 (edited) Liquid soap, pure antifreeze or silcone grease (such as brake lube or dielectric grease). BUT Do not use any petroleum based lubricant such as oil or normal grease. Some rings are oil resistant but unless you know for sure it is safest to avoid any kind of petroleum. Depending on the type of o-ring the petroleum based lubricants cause them to either swell or deteriate. Also do not put them in dry or they may roll and tear or pinch. If your stuck with nothing, spit on it. Edited January 12, 2012 by saddlebum
Yammer Dan Posted January 12, 2012 #5 Posted January 12, 2012 "HOW DO I LUBE MY JOINTS" Jack Daniels:whistling: I would just use the coolant that will be there.
bongobobny Posted January 12, 2012 #7 Posted January 12, 2012 "HOW DO I LUBE MY JOINTS" Jack Daniels:whistling: I would just use the coolant that will be there. I agree...
Venturous Randy Posted January 12, 2012 #9 Posted January 12, 2012 uhhhhhhh... KY Jelly.... I have tube of KY lubricant in the garage. Now, I have never tried the "warming" kind though. RandyA
friesman Posted January 13, 2012 #10 Posted January 13, 2012 I have tube of KY lubricant in the garage. Now, I have never tried the "warming" kind though. RandyA Ive heard it helps for those "cold Starts":whistling: brian
kevin-vic-b.c. Posted January 13, 2012 #12 Posted January 13, 2012 I knew this thread would go sideways, I just never thought it would take that long.
SilvrT Posted January 13, 2012 #13 Posted January 13, 2012 I knew this thread would go sideways, I just never thought it would take that long. That's because we're all getting older......
bongobobny Posted January 13, 2012 #14 Posted January 13, 2012 Hey man, you don't lube your joints, you just light your joints and smoke 'em... (best Tommy Chong voice)
steamer Posted January 13, 2012 #15 Posted January 13, 2012 "HOW DO I LUBE MY JOINTS" Jack Daniels:whistling: I would just use the coolant that will be there.
rstacy Posted January 13, 2012 Author #16 Posted January 13, 2012 I knew this thread would go sideways, I just never thought it would take that long. Like I didn't see that coming when I titled the thread!LOL Thanks for the help guys. I used antifreeze to reassemble the thermostat housing after changing the thermostat and rings. Next I need the big plastic elbow that I ordered and I should be able to reassemble the bike. All of the fairing work is done. Balance the carbs and change the oil and I am ready for spring time!
Flyinfool Posted January 13, 2012 #17 Posted January 13, 2012 Like I didn't see that coming when I titled the thread!LOL Thanks for the help guys. I used antifreeze to reassemble the thermostat housing after changing the thermostat and rings. Next I need the big plastic elbow that I ordered and I should be able to reassemble the bike. All of the fairing work is done. Balance the carbs and change the oil and I am ready for spring time! I'm jealous, I have not even started my winter projects on the bike, And I still have a lot of helies and planks to build to. Spring is coming fast already.
rstacy Posted January 13, 2012 Author #18 Posted January 13, 2012 My buddy rode his ST1300 to work 3 days this week. I would have if mine wasn't in pieces. I forgot to add that my seat is on its way to Rick Butler.
steamer Posted January 13, 2012 #19 Posted January 13, 2012 Hey rstacy, i see you live right here in CNY. Are you planning on attending the International rally in july? It's only 1 1/2 hour ride for you. Everyone from CNY will be there. Plus many others from around the world. Be a great time to put a face:yikes: on the hooligan's you've been talking to here on the site.
rstacy Posted January 13, 2012 Author #21 Posted January 13, 2012 Hey rstacy, i see you live right here in CNY. Are you planning on attending the International rally in july? It's only 1 1/2 hour ride for you. Everyone from CNY will be there. Plus many others from around the world. Be a great time to put a face:yikes: on the hooligan's you've been talking to here on the site. My son and I tend to do a lot of traveling for our model helicopter hobby. http://www.raymondstacy.com/rk2.jpg I am planning on coming if I am free that weekend. I live in Sodus. I have had the pleasure of meeting Jim (Jayceefolly) and Bongobob. They have got to be two of the nicest guys you can ever run in to. I was at Bongobob's July 4th party last year and met a few others as well. I hope that I can make the July rally.
steamer Posted January 13, 2012 #22 Posted January 13, 2012 What Hooligan's??[/quote They are people who cause Shananigans... like you.
mraf Posted January 13, 2012 #23 Posted January 13, 2012 Hey man, you don't lube your joints, you just light your joints and smoke 'em... (best Tommy Chong voice) Thats some cool chit there man. {best Cheech Marin voice}
SilvrT Posted January 13, 2012 #24 Posted January 13, 2012 Hey man, you don't lube your joints, you just light your joints and smoke 'em... (best Tommy Chong voice) uhhhhhh... hey man ... been a while for ya huh? we call 'em doobies now ...
Flyinfool Posted January 13, 2012 #25 Posted January 13, 2012 Ray I still think we may have met without knowing it at IRCHA. If you have ever been to any of the SWARM parties, then I am sure we met. I am the inventor and chief cook of the famous IRCHA Rum Balls.
