ragtop69gs Posted January 12, 2012 #1 Posted January 12, 2012 (edited) I borrowed a FLIR i7 Infrared camera and did some scans of the bike. Interesting, as I found that my left rear cylinder is not firing. These pics were taken in this sequence, Cold, 1 minute, 5 minutes in this order. FR, RR, LF, LR. Each pic is time stamped, the date is wrong. The left rear is dead. Readings at the spark plug also confirm this. Also notice the lower temp at the exhaust pipe on the left. pic 247, 249, 267, 276 are all of the left rear. Now to figure out WHY this cylinder is not firing. I'll post all the pics and maybe it will help someone who knows how to read an IR pic. Edited January 12, 2012 by ragtop69gs
Guest Posted January 12, 2012 #2 Posted January 12, 2012 Could be a bad coil or maybe a bad plug. These bikes are known for developing bad coils. If I remember correctly, Goose posted something about the insulator inside the plug getting corroded. Im sure he will respond.
Cougar Posted January 12, 2012 #3 Posted January 12, 2012 (edited) :sign yeah that:been there done that..... the famous rear coils, Goose will tell you that it is your cap/wire , I myself just changed the coils out. but did that before Goose figured it out. So your # 1 is out and then the # 3 will be later. Also, you did make sure your plug was not fouled correct? Edited January 12, 2012 by Cougar
gibvel Posted January 12, 2012 #4 Posted January 12, 2012 WARNING: If you do decide to take your plug caps apart DO NOT, I repeat, DO NOT use anything abrasive on the end of the small white ceramic resistor in the cap. Doing that will render the resistor, and the cap, useless!! read the how to file before doing it. Edit: Read this post: http://www.venturerider.org/forum/showpost.php?p=389860&postcount=13
ragtop69gs Posted January 12, 2012 Author #5 Posted January 12, 2012 I have not done anything yet to trace the problem, it'll have to wait till the weekend. Can't ride anyway, it's gonna start here tonight
Yammer Dan Posted January 12, 2012 #6 Posted January 12, 2012 HEY!! Thats the best looking 2nd Gen I've seen in a while!!!!:clap2::clap2: Yeah waiting for white crap here too...
Flyinfool Posted January 12, 2012 #7 Posted January 12, 2012 I have not done anything yet to trace the problem, it'll have to wait till the weekend. Can't ride anyway, it's gonna start here tonight The is here right now. I''l pack it up right away and get it over to you for tonight. I sure wish I could borrow a toy like that.
Hummingbird Posted January 12, 2012 #8 Posted January 12, 2012 Did you say that was an SLR camera - if so I think you need to do some adjusting, it appears a little out of focus not all that fond of the color either
ragtop69gs Posted January 12, 2012 Author #9 Posted January 12, 2012 Did you say that was an SLR camera - if so I think you need to do some adjusting, it appears a little out of focus not all that fond of the color either Not out of focus at all. That's my new paint job for the Hippy Fest concert this spring. Think I'll call it Purple Haze
ragtop69gs Posted January 12, 2012 Author #10 Posted January 12, 2012 The is here right now. I''l pack it up right away and get it over to you for tonight. I sure wish I could borrow a toy like that. Just ride on over we'll get a few shots for you
