reddevilmedic Posted September 13, 2012 #51 Posted September 13, 2012 youre very welcome. if you need anything just give me a holler.
jdross440 Posted September 29, 2012 #53 Posted September 29, 2012 I bit the bullet and bought a Rick's high output stator since I had to get the bike back on the road and hadn't been able to get in touch with Skydoc_17 about his that had failed. Got it installed today and now have good voltage. 13.5 at idle with everything on, radio, driving light, high beam. This is better than the one that failed did new.
twigg Posted September 29, 2012 #54 Posted September 29, 2012 jdross440 said: I bit the bullet and bought a Rick's high output stator since I had to get the bike back on the road and hadn't been able to get in touch with Skydoc_17 about his that had failed. Got it installed today and now have good voltage. 13.5 at idle with everything on, radio, driving light, high beam. This is better than the one that failed did new. What is the voltage at 2000 rpm? Idle voltage on a stator doesn't tell you a great deal other than it is putting out voltage. You are looking for over 14V and under 15V
