bknsaddle Posted December 27, 2011 #1 Posted December 27, 2011 So I finally decided to bite the bullet and put LEDs for the '06 RSTD on my list for the fat guy in the red suit. He came through, and became the proud owner of the Custom Dynamics 100 LED tail light and a Turn Signal conversion kit. My need for immediate gratification meant that I installed the tail light first.....and man that thing is bright! My next step, and where my disappointment started, was to try out the turn signals. I'm no Rocket Surgeon, but I figured this was going to be fairly simple. Well, after 30 minutes of trying to figure out why the front LEDs would not fit properly, I tried the rears and found the same problem. They had a diameter about 1/16 of an inch too large. My disappointment drove me to send an email to CD, and I was surprised to get a response on Christmas Day. Although Dave from CD said they should fit, I could find no way they could be mounted without screwing up the weather seal or mounting them cockeyed in the lens. Alas, this morning I shipped them back to CD for a refund and am now looking for alternatives. Anyone else encounter this problem? Alternative sources?
XV1100SE Posted December 27, 2011 #2 Posted December 27, 2011 I documented my experience... was great response from Custom Dynamics and no issue with the signal lights. You sure they sent you the right ones? http://www.venturerider.org/forum/showthread.php?t=63006&highlight=custom+dynamics Are these the ones you ordered? What part number did you get? 7507 is the connector type. http://www.customdynamics.com/yamaha_turn_signal_retro.htm
bknsaddle Posted December 27, 2011 Author #3 Posted December 27, 2011 I thought the response from CD was great, as I never expected to hear from them on Christmas Day. The problem was not with the bases, but with the board the LEDs are on. They were just a little too big to fit in. Maybe they got a bad batch..... I do love the tail light!
XV1100SE Posted December 27, 2011 #4 Posted December 27, 2011 Did you get the turn signals or the run/turn/brake?
Guest Slab_Ryder Posted December 28, 2011 #5 Posted December 28, 2011 Mine had to be glued to the Bezel.
XV1100SE Posted December 28, 2011 #6 Posted December 28, 2011 Mine had to be glued to the Bezel. Interesting.... mine fit in place fine. Must be having some pretty big quality problems if they can't do a consistent size !
SMSgt Posted December 28, 2011 #7 Posted December 28, 2011 OK guys so I'm wanting to change my lights to LED also. Can someone give me a reliable source and part numbers for tail light and front and rear turn/running lights? I would prefer a red for the tail light because I would like to go to a clear tail light and clear rear turn signal lenses. Thanks Kent
bknsaddle Posted December 28, 2011 Author #8 Posted December 28, 2011 Did you get the turn signals or the run/turn/brake? I had the turn signals.
lonewolf96 Posted December 28, 2011 #9 Posted December 28, 2011 I had the same issue with the ones I ordered not fitting inside the lens. A little 300 grit sand paper fixed the problem. The board is plastic so you can sand the edges pretty easy and get them down to size with no ill effects.
RandyR Posted December 28, 2011 #10 Posted December 28, 2011 I had the same issue with the ones I ordered not fitting inside the lens. A little 300 grit sand paper fixed the problem. The board is plastic so you can sand the edges pretty easy and get them down to size with no ill effects. If thats 'the way they are', then the sales page and installation instructions should say so. Although at the price they cost, it should be a drop in fit. btw they are on sale thru New Years.
lonewolf96 Posted December 28, 2011 #11 Posted December 28, 2011 I would have thought they would have fit in the housings better too. I have a backyard engineering degree so I found a way to make them work.
bknsaddle Posted December 28, 2011 Author #12 Posted December 28, 2011 While I have a degree from the MacGyver School of Make it Work, the older I get the less inclined I am to redesign/modify expensive stuff that should have been made correctly in the first place. Wife says I'm getting "grumpy"..... I think I'll just keep my eye out for an alternative.....
aharbi Posted December 28, 2011 #13 Posted December 28, 2011 I installed the Moon Shinez™ LED in the front last year and I used my dremel tool to trim down the diameter so they would "drop-in" and the lens would mate with the rubber gasket.
Dave77459 Posted December 28, 2011 #14 Posted December 28, 2011 If thats 'the way they are', then the sales page and installation instructions should say so. Although at the price they cost, it should be a drop in fit. btw they are on sale thru New Years. I wonder if everyone is missing this bit (red bold mine):Our New Moon Shinez™ provide a exceptional bright cool white driving light while still providing front turn signal functionality. At approximately 6000K these Genesis® II White LEDs with Eclipze® Technology provide the same color as most HID kits and come with a Lifetime Warranty Against LED Failure. Our Moon Shinez™ must be used with a Clear or Smoked Lens (Sold Separately) Does that explain the improper fit with stock lenses? Dave
bknsaddle Posted December 28, 2011 Author #15 Posted December 28, 2011 LEDs in question were not Moonshines, and according to CD were supposed to work with stock lenses. Now that I know that others have had the same issue, I'll shoot them an email and suggest they change the application info.
stroker ace Posted December 29, 2011 #16 Posted December 29, 2011 Mine fit no modifications ( had mine a few years though ).
Bummer Posted December 29, 2011 #17 Posted December 29, 2011 I had the same issue with the ones I ordered not fitting inside the lens. A little 300 grit sand paper fixed the problem. The board is plastic so you can sand the edges pretty easy and get them down to size with no ill effects. I used a file. Took a couple of minutes to do all four. I'd rather they were too large than too small. Too large I can fix.
