cabreco Posted December 26, 2011 #1 Posted December 26, 2011 Do these covers do anything, or are they just for show? Mine are oxidized & I want to polish & paint them. If I take them off to redo them I won't have to replace any gaskets or cause a leak?
friesman Posted December 26, 2011 #2 Posted December 26, 2011 You are ok to take them off to redo them and reinstall, but dont run the engine while you have them off. THose covers hold the rubber antifreeze drain plugs in place while the engine is hot with the cooling system under pressure. Brian
cabreco Posted December 26, 2011 Author #3 Posted December 26, 2011 Thanks for the heads up. I figured I would ask before taking them off. I have enough work to do on this teardown without CREATING more fixes! Andy
Midicat Posted December 27, 2011 #4 Posted December 27, 2011 Not for nothin', but what would you do to refinish those? What does the finished product look like? Post pics of finished pieces, please. Thomas
cabreco Posted December 27, 2011 Author #5 Posted December 27, 2011 Not for nothin', but what would you do to refinish those? What does the finished product look like? Post pics of finished pieces, please. Thomas I was basically planning on running them through a dremel with a buffer attachment using polishing rouge. The finished result would make the aluminum appear to look like chrome. Then I would just repaint the black ridges. As I start refinishing I will post pix. I'm also going to post pix of my plastic welding the cracks in the fairing as well as the broken ABS tabs. Andy
dingy Posted December 27, 2011 #6 Posted December 27, 2011 (edited) Here is a couple of pictures of sideplates on my 83. They have been cut down in length to clear the different configuration of the Vmax heads. They were polished, then powder coated. Then I sanded through the powdercoat to expose aluminum & polished them back out. Gary Edited December 27, 2011 by dingy added current picture
