kwisor Posted December 18, 2011 Posted December 18, 2011 hello all well my luck went from bad to worse in sept i got layed off now filing bankruptcy lost my truck only have mt 99 rsv to look for job i cleaned my air filters today and went to start the bike and when i hit the starter there was a clunk sound and will not turn over tryed a cupple more times same thing walked away and went back now nothing no clunk sound nothing also it will not shift from nutrul to any gear stays in nuetral any thing i can ck or do to see what is going on last week on tue i had a job intervew and on the way the fuel pump went out fixed that but didnt make intervew please help bumble bee
friesman Posted December 18, 2011 Posted December 18, 2011 Sorry to hear that youre having a tough time with things. I am sure it will turn around for you shortly. I dont know what your scoot's issue might be but I am sure someone will be along shortly that can help get you going. brian
Freebird Posted December 18, 2011 Posted December 18, 2011 I would suspect the battery first of all. Don't know how old it is but check the connections and then maybe have the battery itself load tested. Most parts stores or even Walmart will do that for free. If you have a good charger, just put it on the charger for a couple of hours and then try it again. It will probably shift OK once you get it started and then maybe rock it back and forth a couple of times.
kwisor Posted December 18, 2011 Author Posted December 18, 2011 hello i cked the siloned and with a test light and did not get power to the starter side the fuse was good i had another one changed it and it started up glade i had a extra one but it seemed like smothing locked up but i do not know everyone have a marry xmass and happy new year bumble bee
