goatman123 Posted December 18, 2011 #1 Posted December 18, 2011 I changed my tires, and when putting the rear one back on, I forgot where one of the washers goes. On the right side, there is a washer that goes on one side of the brake mounting bracket or the other. Can someone tell me which side? This is a washer that goes on the rear axle, and it will either be up against the wheel on the right side, or between the swingarm and the brake mounting bracket. I put it up against the wheel, but is seems like there may be too much drag from the brake when I spin the wheel. Thanks for any help.
Squidley Posted December 18, 2011 #2 Posted December 18, 2011 goatman123 said: between the swingarm and the brake mounting bracket. Thats where it goes, it doesn't touch the actual rim
goatman123 Posted December 18, 2011 Author #3 Posted December 18, 2011 An answer in two minutes, that's a record. Thank you very much.
Bubber Posted December 18, 2011 #4 Posted December 18, 2011 goatman123 said: An answer in two minutes, that's a record. Thank you very much. That's because Squidley doesn't have a life and spends every waking minute on the site. :rotf: But then I have been accused of that too. :moon: Merry Christmas all!
rstacy Posted December 18, 2011 #5 Posted December 18, 2011 This thread helped me when I did mine http://www.venturerider.org/forum/showthread.php?t=515 http://www.venturerider.org/wheel/MVC-250F.JPG
