playboy Posted December 15, 2011 Posted December 15, 2011 Does you tube always Take so long to load or is it just my pc Hard to watch some of these post take forever. Watch a few seconds wait a few minutes watch a few seconds wait a few minutes by then I forgot the begining
friesman Posted December 15, 2011 Posted December 15, 2011 you must have a slow network connection or computer. Occasionally I will get a video that everyone is watching and the traffic slows the video stream down, but usually its like watching tv. Brian
wizard Posted December 15, 2011 Posted December 15, 2011 I have the same issue with my computer. I can't view the U-tube about welding plastic recently posted.
dmoff1698 Posted December 15, 2011 Posted December 15, 2011 I too have a slow connection. So here is what I do. When I come across a link, I continue to read the comments and try to judge whether I would even be interested. If so, I open the link in a new tab. As soon as the video starts loading I hit the pause button. The video will continue to load but won't be playing. While I wait for the video to finish loading, I can return to the old tab and continue to read other threads while I wait. Doesn't make the video load any faster, but allows me to be doing something while I wait.
Bubber Posted December 15, 2011 Posted December 15, 2011 As Ed McMann said "I did not know that". I will have to try that next time.
Flyinfool Posted December 15, 2011 Posted December 15, 2011 Yup same here, it is not my computer that is slow. This is on a high end computer used for doing 3D CAD work. It is the internet connection that is not much faster than dial-up. I start the vid, hit pause till it is done loading, and then you can view it all the way thru.
Steel Horse Cowboy Posted December 15, 2011 Posted December 15, 2011 (edited) I too have a slow connection. So here is what I do. When I come across a link, I continue to read the comments and try to judge whether I would even be interested. If so, I open the link in a new tab. As soon as the video starts loading I hit the pause button. The video will continue to load but won't be playing. While I wait for the video to finish loading, I can return to the old tab and continue to read other threads while I wait. Doesn't make the video load any faster, but allows me to be doing something while I wait. Yup same here, it is not my computer that is slow. This is on a high end computer used for doing 3D CAD work. It is the internet connection that is not much faster than dial-up. I start the vid, hit pause till it is done loading, and then you can view it all the way thru. Yep, this is the best way to do it. I do about all the online videos that I watch this way. I also always click on the YouTube symbol in the bottom right corner and go directlty to YouTube to watch it. Seems to load better that way. C.R. Edited December 15, 2011 by Steel Horse Cowboy add more info.
skydoc_17 Posted December 15, 2011 Posted December 15, 2011 The video files are downloaded into the area called "Temporary Internet Files". It has a finite amount of space. Before watching a video, go to the tool bar at the top of the page and select the "Tools" drop down menu. (windows XP) At the bottom of the drop down, you will see "Internet Options" click this. You will see Clear Browsing history, cookies, Temp Internet Files, etc. Click the delete button below this section. (First delete button in drop down. don't worry, nothing happens YET!) You will get another drop down with the different selections. Select Temporary Internet Files, (No need to select anything else) then click the delete button at the bottom of this drop down. Then select OK and View your video. Earl
SilvrT Posted December 16, 2011 Posted December 16, 2011 The video files are downloaded into the area called "Temporary Internet Files". It has a finite amount of space. Before watching a video, go to the tool bar at the top of the page and select the "Tools" drop down menu. (windows XP) At the bottom of the drop down, you will see "Internet Options" click this. You will see Clear Browsing history, cookies, Temp Internet Files, etc. Click the delete button below this section. (First delete button in drop down. don't worry, nothing happens YET!) You will get another drop down with the different selections. Select Temporary Internet Files, (No need to select anything else) then click the delete button at the bottom of this drop down. Then select OK and View your video. Earl This may work but not necessarilly. I have experienced the same issue with vids and it doesn't matter if they are youtube or from some other place. In my case it is intermittent so I just chalk it up to high server load or high traffic load over the "pipe" that the vid is travelling on. If it's bogging down at 1PM, then go back at 2 or 3 PM and see if it's any different.
playboy Posted December 16, 2011 Author Posted December 16, 2011 The video files are downloaded into the area called "Temporary Internet Files". It has a finite amount of space. Before watching a video, go to the tool bar at the top of the page and select the "Tools" drop down menu. (windows XP) At the bottom of the drop down, you will see "Internet Options" click this. You will see Clear Browsing history, cookies, Temp Internet Files, etc. Click the delete button below this section. (First delete button in drop down. don't worry, nothing happens YET!) You will get another drop down with the different selections. Select Temporary Internet Files, (No need to select anything else) then click the delete button at the bottom of this drop down. Then select OK and View your video. Earl I go to the control panel and do this nearly every time I log off and then go to my wife and shared users and do there's every once in awhile. Glad I'm not the only one in this boat. Thanks
playboy Posted December 16, 2011 Author Posted December 16, 2011 I have to do the start and pause thing also.
etohio Posted December 16, 2011 Posted December 16, 2011 I too have a slow internet connection. So what I did is use a browser called Modzilla and save the file and use VLC Media Player to play the vid.
Venturous Randy Posted December 16, 2011 Posted December 16, 2011 It matters a lot on my laptop if I am wireless or hard wired. Due to my wireless going pooey last week, I am now hard wired. It is much faster. RanyA
SilvrT Posted December 16, 2011 Posted December 16, 2011 I go to the control panel and do this nearly every time I log off and then go to my wife and shared users and do there's every once in awhile. Glad I'm not the only one in this boat. Thanks You can force your browser to clear your temp files automatically each time you exit it. There are a couple settings in IE that everyone should consider setting ... and they are; First, go into Tools | Internet Options Where it says "Browsing History", click on Settings In there (Temporary Internet files and History Settings), select "Every time I visit the web page" Click OK and then go to the Advanced tab Scroll down to the Security section Check the box for "Empty temporary internet files folder when browser is closed" Click OK until you are out, close and re-open IE
