I use a hollow TX-25 on the Security Bolt.
It's no wonder that you feel some extra Power when the Hose is kinked to a point where the Case Breather is tight. This creates Pressure inside the Casing and lead to more Pump Losses, costing Power.
  • Replies 331
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Was a set of Diaphragms somewhere on E-Bay for decent price. Just got diaphragms. Had to put them on your slides. Maybe someone has addy to them. I'll look but don't think I have it.
Thank you . I hope I'm not bidding against somebody on here. How much did you pay this guy for yours ? :confused24:
This guy never does these with a buy it now, always an auction.
I was only bidder on mine, so whatever opening bid was.
I farmed out putting these on sliders to Earl. That's only the 2nd thing that anyone has done on my bike except for me, not counting tire mounts though. Other was machine work on block. 3rd will be front brake brackets when I get them.
Gary
Gary
Not a big job. Can't remember but think it was starting price.
  • 2 months later...
I finally have some time to put the new diaphragms on the 87. The diaphragm installation and the new spacer on the needle went fast, just want to know if I should:
1) Use any lock tight on the outside housing screws on the cap?
2) Use any sealer around the metal cap that goes over the diaphragm ?
Seems like the diaphragm is it's own seal(er) but though I would ask before I put it all back together.
:confused24:
1) Use any lock tight on the outside housing screws on the cap? NO!
2) Use any sealer around the metal cap that goes over the diaphragm ? NO
:confused24:
See above comments.
  • 2 weeks later...
Okay my guru friends…
I’m working on the 87. Just put in the new diaphragms over the weekend and cleaned the carbs in that area. Already did the super duper SeaFoam flush. The Bike still runs like crap.
Just put in new plugs today and checked the wires and caps for resistance. That is documented below.
QUESTION: I also found the vacuum looking hose hanging from the front left ( not the one that goes from the carb base up) and I can’t figure where this hose goes and why it is disconnected. ( picture below) I followed the his e up with my hand and it feels like it connects to some type of nipple at the bottom of the upper left fairing. Any ideas ??
So, after checking the plug wires for resistance, I did find one problem with one plug wire. The stats are these:
LF – 23.4
LR – 35.5
RF- 23.2
RR – 23.1
So having the high resistance in the left rear, I pulled the cap and got a reading of 8.9. The right rear cap was 9.0.
The left rear wire without the cap was 26.9 and the right rear with out the cap was 14.2.
So, if I remember correctly, all the readings except the left rear wire are good.
QUESTION: So how would a wire reading of 26.9 affect the running of the bike ?
QUESTION: Also, I tried to remove the cap on the Idle Mixture screws. I drilled a small hole, screwed a screw into it and tried to "pop" it off. They didn't pop off. Should I drill the whole thing out or will it pop out some how ?
:confused24:
Edited by KIC
Might be the hose to the vacuum sensor, should hook to #2 carb via a reducer nipple & another hose.
Gary
There already is a hose from the #2 carb going up in the direction of where it should go. This hose appears to be a different hose.
The plugs will pop out but not easy.
Okay, thanks.. I'll give it a little more Ummph on the pop out attempt
Are these orginal wires? Could make a lot of difference when under load. I get lost on the electrical stuff. Just grab the plug wire..if your boots stay on it might need replaced. At least thats my method. I do have a spark checker that you can increase distance it will arc that has helped me at times. Again I just go by what I feel on this. I'm sure there will be a lot of help."Brown Sugar" don't seem to be suffering much from putting up with my methods. Lace up your boots and get busy.....
Gary
Fits into a tee about where it is hanging. Check you other bike?? It does look like sensor hose which could affect way it runs. Slower revs?? Right Dingy??:think:
It appears you have the side cover off, so you may be able to see where it is going. I can't remember another vacuum hose in that area, other than the vacuum sensor.
The vacuum sensor is attached to the rear of the coil rack, there is a 3 wire plug going into it from the bottom and a hose.
Gary
Gary
I will have to disassemble more of the bike/fairing area to be able to see more in that area. I'm wondering if it has anything to do with the cruise control ? Isn't there some vacuum type lines that run across the front of the fairing ?
do you maybe have a cali bike and that is one of the hoses for
the evap system? maybe partly removed by PO?
I don't think this one is a Cali bike. I know there is a way to tell from the VIN or Model number, but will have to research that to find out how. I don't see that long black breather thing up above the front of the engine.
WELL? We are waiting... Plug didn't shock ya that hard did it??:whistling::whistling:
No shock.. to cowardly :shock3:
Symptoms are hard to start cold. Use all choke. Runs like crap and is hard to accelerate the engine speed without it crapping out. once it warms up, i can use less choke but never none.
Very slow to accelerate RPMs with throttle, choke will accelerate RPMs some.
One interesting thing I noticed:
When cranking over, or when idling on it's own, the throttle bounces back and forth. Almost looks like a ghost is giving it a little gas. It is also in rhythm with the engine idle sound. I have ridden it around the block a couple of times but it runs so bad, doesn't accelerate rapidly, although it seems to try over a distance, or decelerate well at all. :confused24: Also sounds like a small back fire at times from a rear cylinder.
I am going to try cleaning a few more of the jets etc. I want to do anything but pull the rack. :shock3:
Oh yea..the new plugs didn't make any difference. Neither did the new diaphragms.
I would do a real strong soak again. Might save pulling them which I hate. I mix in a can for real strong soak about 3/4 Sea-Foam 1/4 gas. Or use the BerryMans Chem Tech at wally world for about 1/2 the cost. I don't like to use a lot of it because it is a little harsher but in some cases might clean what Sea-Foam won't.
Guess it's worth trying again. What I did last time was to disconnect the gas line, put my own onto the fuel pump and pumped in a very rich SeaFoam mixture into the carbs. Let them sit for 2 days, started it up and stunk up the garage and neighborhood for that matter.
Did it again. Then ran a cleaner gas mixture through it. I just switched to pure gas and let her idle for 30 minutes revving the RPM's up every once in a while. Then I went around the block several times. I'll play with it this weekend, try to clean some more jets etc then soak it again.
If your interested in a 2nd gen, there is a 99 listed in the Tucson craigslist for $4800.00 Nov 13th posting. Maybe he will deal.
Actually, I picked up that bike... and we settled at $4300. So far, had to pull apart the fairing and re-grease the connections and most recently, my rear shock went out. Not bad considering I've already put over 5000 miles on it since January.
Edited to completely rewrite!!!!
Hose from #2 carb to vacuum sensor:
When it is disconnected from the air box the bike idles wonderfully.
When I hook it up the idle jumps to 3200 rpm.
I have checked for air leaks around the carbs and that is not an issue.
so what is the problem? Why the jump in idle rpm?
I ended up just dialing back the idle with the hose connected to vacuum sensor attached.
It seemed reasonable!
KIC.....is there any chance that hose is the one that goes from the airbox (front left) and "t"'s into the other airbox hose? The one that goes into the tube between the carbs on the "box" on top of the crankcase?
http://www.venturerider.org/forum/attachment.php?attachmentid=65439&d=1332797233
see illustration #3
Edited by Trader
