many years ago, I saw a fire truck extend its ladder out with a guy on the end. just his weight, flipped the ladder truck over, and all the support legs were down. the proper leverage will move mountains
I used to rig for cranes like that one and bigger. You would be surprised at what will tip one over with that much stick out. That was only about a 70 or 90 ton crane.
Yeah, but not fully extended!!
I had a fiberglass pool put in back in 1994. But I did not have a fence up yet and there was a street behind the back yard. Did not have that problem. But I did have to get a variance from the city to put it in. Because with the street there my back yard was consider a front yard.
Exactly. Their max lift capacity is the main boom in an almost a vertical position, 10ft from center.
When I worked in the Virgin Islands I had a 80 foot boom truck. There is always a good breeze blowing there. One day I was on top of Crown Mountain the highest spot on the Island. Thought I would take a look and shot that boom straight up in the air. That breeze becomes a wind up there!! Still don't know how the view was up there. As soon as it hit the top it started over. I hit the down button and dropped as quick as I could. Lot of rocking and slid truck sideways about three feet with outriggers down. That was probally pretty close. that was the last time I tried that!!
Made you have to change your shorts I bet. I have seen them up on 2 outriggers when trying to get that last little bit of reach, several times.
Change shorts?? I had to wash the bucket out!!
