Jethroish Posted November 21, 2011 #1 Posted November 21, 2011 Cleaning the windshield today, I noticed one side is very loose (broken mount). Warranty is good until Feb 28, 2012. I know there is a "fix" in the tech section, but will Yamaha do anything about it under warranty?
Eck Posted November 21, 2011 #2 Posted November 21, 2011 Yes they will and should. However, I personally would not trust some yocal yamaha tech to tear my Venture down to replace the inner fariring just because the littel tabs are broke. The fix is very easy to do and will remain repaired (fixed) for years to come. If you choose to let a local Yamaha tech replace your inner fairng, you can bet in about a month those same tabs will be broke again and your right back at square one but "without" warrenty coverage... I would just do the easy fix and for get about it.... Thats my 2 cents... for what it's worth..
TDunc Posted November 21, 2011 #3 Posted November 21, 2011 Eck, have you done that fix? If so, my crystal ball sees a possible trip with dinner in store for you! :big-grin-emoticon: My 06's tabs are in the same state and warranty goes in FEB too.
Midrsv Posted November 21, 2011 #4 Posted November 21, 2011 I had my fairing replaced on my '07 due to the cracked areas around the windshield mounting holes. Make sure you have the two center bolts in the metal support bracket. Mine did not. Here is a thread from when mine was replaced. http://www.venturerider.org/forum/showthread.php?t=44756 Dennis
Eck Posted November 21, 2011 #5 Posted November 21, 2011 Quote Eck, have you done that fix? If so, my crystal ball sees a possible trip with dinner in store for you! Yes, I did the fix on my 05 back when I had it. Dinner is not required.. riding afterwards is.. I have the material needed to fix it too. Now.. as for getting together to do the fix is the next problem, for I dont see where I have enough time off work to come up to NC until next year..??? It is an easy fix and I can walk you through it if you want on the phone as you do it. Just let me know a day or two in advance so I can go get a 6 pac and sit so I can sit and tell you how..
TDunc Posted November 22, 2011 #6 Posted November 22, 2011 Sounds great to me. Eck said: Quote Eck, have you done that fix? If so, my crystal ball sees a possible trip with dinner in store for you! Yes, I did the fix on my 05 back when I had it. Dinner is not required.. riding afterwards is.. I have the material needed to fix it too. Now.. as for getting together to do the fix is the next problem, for I dont see where I have enough time off work to come up to NC until next year..??? It is an easy fix and I can walk you through it if you want on the phone as you do it. Just let me know a day or two in advance so I can go get a 6 pac and sit so I can sit and tell you how..
