darthandy Posted November 19, 2011 Share #1 Posted November 19, 2011 Well my body decided to give me a break and I was able to get back to working on the RSV. I have installed the accessory fuse block , the ignition relay and emergency bypass (Between the relay and ignition switch as per one of the schematics I found here, thank you) and have run a couple of 14 gauge "hot" wires from the new fuse block up to the fairing for the relay to the lights and one for ...well, whatever I think of next. Now I was about to remove the ignition switch to repair it since Mike (eusa1) has kindly offered to guide me through the work (Where else can you get this kind of help?) but, here's where I hit a snag. I don't have a bolt extractor so I was going to use a dremel tool to slot the bolt heads and use an impact driver to remove the bolts, but it looks as if even my smallest 15/16 in. wheel will cut into the switch housing before I have a usable slot. What size cut off blade did those who did it this way use? Also does anyone know what size bolts I'll need to replace the ones I remove? Or are they re-usable if I remove them this way? Once this is done, I'll be splitting the fairing to install a relay for the driving lights and headlight, but first, I want to complete this work. Link to comment Share on other sites More sharing options...
muffinman Posted November 20, 2011 Share #2 Posted November 20, 2011 They can be reused If you slot them I want to say they are 6 mm if you don't have a small enough cutting wheel drill them and use a chisel to turn them out Link to comment Share on other sites More sharing options...
