GaryZ Posted November 17, 2011 #1 Posted November 17, 2011 My question for today is; Will a 1200 Vmax TCI plug-n-play on my 1985 Venture? It seems to make sense because I have Vmax cams . . .
Yammer Dan Posted November 17, 2011 #2 Posted November 17, 2011 I was thinking it would but we better wait for the experts. I think it will....
bongobobny Posted November 17, 2011 #3 Posted November 17, 2011 Hmmmm! Might work, the response curve would be different but seeing as you have VMax cams that might be a good thing. I guess the answer would be does the VMax have dual pickups like your '85 has...
GaryZ Posted November 17, 2011 Author #4 Posted November 17, 2011 Hmmmm! Might work, the response curve would be different but seeing as you have VMax cams that might be a good thing. I guess the answer would be does the VMax have dual pickups like your '85 has... I checked the 1995 Vmax circuit diagrams and found they show the same dual-pick up/4x as shown in the 1985 VR. Can I assume all 1200 Vmax's were the same?
dingy Posted November 17, 2011 #5 Posted November 17, 2011 VMax went to the single pickup coil in 1990, same year as the Venture did. Gary
GaryZ Posted November 17, 2011 Author #6 Posted November 17, 2011 VMax went to the single pickup coil in 1990, same year as the Venture did. Gary What would it take to convert to single pick-up?
dingy Posted November 19, 2011 #7 Posted November 19, 2011 Replace rotor, stator cover, pick-up coils, TCI. Probably tweak the wiring harness a little. Gary
GaryZ Posted November 19, 2011 Author #8 Posted November 19, 2011 Gary, I researched the parts that you mentioned. The goal is to have one pick-up coil instead of four. Could one of my pick-up coils be physically located in the same spot as the single coil? Couldn't I re-wire the harness? Do you have any Universal TCI Kits left for a Vmax?
dingy Posted November 22, 2011 #9 Posted November 22, 2011 Gary, I researched the parts that you mentioned. The goal is to have one pick-up coil instead of four. Could one of my pick-up coils be physically located in the same spot as the single coil? Couldn't I re-wire the harness? Do you have any Universal TCI Kits left for a Vmax? I think you have about a snowballs chance in Hell of that working. Chance of either one of the rotor lobes and one of the 4 timing coils having the proper alignment to match what was done on the 90-93 are extremely slim. But then people play the lottery ever day with a million to one chance at hitting. Wiring harness would by far be the easiest part. Since there is zero adjustment in the timing at the pickup coils the lobe & coil would have to be perfect to match a stock TCI. The Ignitech unit would probably be doable as the timing is adjustable in the TCI via a computer hookup. It would be an interesting and probably frustrating project though. Gary
GaryZ Posted November 22, 2011 Author #10 Posted November 22, 2011 I think you have about a snowballs chance in Hell of that working. Chance of either one of the rotor lobes and one of the 4 timing coils having the proper alignment to match what was done on the 90-93 are extremely slim. But then people play the lottery ever day with a million to one chance at hitting. Wiring harness would by far be the easiest part. Since there is zero adjustment in the timing at the pickup coils the lobe & coil would have to be perfect to match a stock TCI. The Ignitech unit would probably be doable as the timing is adjustable in the TCI via a computer hookup. It would be an interesting and probably frustrating project though. Gary But, do you have any Universal Kits left?
dingy Posted November 22, 2011 #11 Posted November 22, 2011 But, do you have any Universal Kits left? Not at this time, but I think I will try to get another group buy together after the Holidays are over. Gary
