saddlebum Posted November 15, 2011 Posted November 15, 2011 (edited) When I worked for Freightliner we used a burn test, using a simple lighter or small torch, to determine the type of plastic we were working with, prior to repairs. The chart we used was very similiar to this one. http://www.boedeker.com/burntest.htm EXAMPLE Ignite the material with a lighter. Note the burning characteristics of the material. A slow burning yellow flame with green edges dispelling white smoke that does not drip molten material signifies the material is PVC plastic. Edited November 15, 2011 by saddlebum
Yamamike Posted November 15, 2011 Author Posted November 15, 2011 Huh! Very interesting...I must perform a scientific test this evening!
saddlebum Posted November 15, 2011 Posted November 15, 2011 When I worked for Freightliner we used a burn test, using a simple lighter or small torch, to determine the type of plastic we were working with, prior to repairs. The chart we used was very similiar to this one. http://www.boedeker.com/burntest.htm EXAMPLE Ignite the material with a lighter. Note the burning characteristics of the material. A slow burning yellow flame with green edges dispelling white smoke that does not drip molten material signifies the material is PVC plastic. Here is a more simplified comparison. Polyvinyl Chloride (PVC) Yellow flame w/ green spurts Plastic does not drip Self extinguishing Smells like hydrochloric acid Plastic chars Acrylonitrile Butadiene Styrene (ABS) Orange flame Plastic drips Burns slowly Black smoke w/ soot (floating particles) Acrid odor
Yamamike Posted November 16, 2011 Author Posted November 16, 2011 Thanks Saddlebum! Didn't have a change to experiment last night...hopefully tonight!
a1bummer Posted November 16, 2011 Posted November 16, 2011 This method is use by many of us in the scientific community in our labs in a controlled environment called "Flame Emission Spectroscopy". Here's a "WIKI" link, http://en.wikipedia.org/wiki/Emission_spectroscopy#Emission_spectroscopy Thanks Bill When I worked for Freightliner we used a burn test, using a simple lighter or small torch, to determine the type of plastic we were working with, prior to repairs. The chart we used was very similiar to this one. http://www.boedeker.com/burntest.htm EXAMPLE Ignite the material with a lighter. Note the burning characteristics of the material. A slow burning yellow flame with green edges dispelling white smoke that does not drip molten material signifies the material is PVC plastic.
Frank3 Posted November 17, 2011 Posted November 17, 2011 I haven't inspected any of the panels on my VR yet , but most ABS will also have TPS stamped in it . This stands for thermal setting plastic . I believe most if not all ABS is also TPS . The reason I mention this is because it is possible to ' weld ' , and heat to shape . This can be done with a soldering iron with a spoon , or flat tip instead of the normal pencil tip ( most irons come with multiple tips ) , or a hot air welder which Northern Tool sells . You will also need filler material , filler rods also at Northern , or any scrap on the same plastic , even pipe . I have used this method by heating a screwdriver with a flame , and using it to melt and push the plastic around . Over heating the plastic can make it brittle , so some practice is required . Out of all the methods listed in this thread , I have found welding to be the strongest . With the thin panels on these bikes , a combination of methods may be the best approach . What ever works best for you .
