Kregerdoodle Posted October 25, 2011 #1 Posted October 25, 2011 not sure if I need srings or just change the fork oil, I am getting a bounce in the front end between 30 and 35, took the wheel off and re-ballanced, it was spot on, so thats not it, put a peice of card board in a clamp and set it allmost to the tire and spun the wheel, not out of round.... it is an `01 so springs are probably shot, just reaching for Ideas.. Thanks
flb_78 Posted October 25, 2011 #2 Posted October 25, 2011 Both. But you can probably get away with just changing the oil. I used ATF when I resealed the forks on my 99.
darthandy Posted October 25, 2011 #3 Posted October 25, 2011 A bounce happening at such a specific and relatively low speed doesn't really sound like a spring problem. More like a balance problem, although one would expect it to get worse rather than go away at higher speeds (I'm assuming it foes away since you mentioned 30 to 35). If the springs were sacked out, you would expect the bike to ride a bit lower and maybe ground out sooner on turns or bottom out on bumps. We'll have to see what the forum experts have to say I guess. Andy
Kregerdoodle Posted October 26, 2011 Author #4 Posted October 26, 2011 I should also have mentioned that if I hit the front brakes the bounce will go away and when I stop hard with the front brake the bike will go down pretty far and not really come all the way back up untill I give it gas.. A bounce happening at such a specific and relatively low speed doesn't really sound like a spring problem. More like a balance problem, although one would expect it to get worse rather than go away at higher speeds (I'm assuming it foes away since you mentioned 30 to 35). If the springs were sacked out, you would expect the bike to ride a bit lower and maybe ground out sooner on turns or bottom out on bumps. We'll have to see what the forum experts have to say I guess. Andy
Owen Posted October 26, 2011 #5 Posted October 26, 2011 I should also have mentioned that if I hit the front brakes the bounce will go away and when I stop hard with the front brake the bike will go down pretty far and not really come all the way back up untill I give it gas.. Dang Doodle! I told you to lay off the snacks!
Rick Butler Posted October 26, 2011 #6 Posted October 26, 2011 Kreg, What you describe is a classic (compression/rebound) dampening issue. In other words your oil has turned the consistency of water and is shot. It is also a 7.5 wt which is very thin.....the same weight that a sport bike with cartridge forks requires. It needs at least a 10wt. And I will suggest that the bottom of your forks are filled with a black sludge? But when you talk about the front end diving a bunch, your issue is that the springs have lost all of their sag....yeah they are shot as well. The oem spring rate is .90kg/mm and what these bikes need is a spring rate of 1.2kg/mm. And while you have the forks out to change the fluid, you should go ahead and replace the springs. The most convenient thing to do would be to use Progressive brand springs (which are a multiple spring rate) but most experts say you really need a constant rate 1.2 kg/mm spring that you can get from Race Tech, Sonic Springs (which I reccommend) and several other suppliers. But this is not an easy task which will take most of a day to complete. You have to pull the fairing off and suspend it in order to get the forks out to drain, etc. Hope this helps, Rick I have a set of springs (and cartridge emulators) to install on a friend's RSV later this year, so maybe I'll go ahead and work up a detailed set of instructions? not sure if I need srings or just change the fork oil, I am getting a bounce in the front end between 30 and 35, took the wheel off and re-ballanced, it was spot on, so thats not it, put a peice of card board in a clamp and set it allmost to the tire and spun the wheel, not out of round.... it is an `01 so springs are probably shot, just reaching for Ideas.. Thanks
Kregerdoodle Posted October 26, 2011 Author #7 Posted October 26, 2011 Thanks Rick, that helped alot.. I kinda figured that after 10+ years that they are shot, but knowing what a job it is going to be, thought I would ask. gonna be a Dec. job. for sure. Thanks again. Kreg, What you describe is a classic (compression/rebound) dampening issue. In other words your oil has turned the consistency of water and is shot. It is also a 7.5 wt which is very thin.....the same weight that a sport bike with cartridge forks requires. It needs at least a 10wt. And I will suggest that the bottom of your forks are filled with a black sludge? But when you talk about the front end diving a bunch, your issue is that the springs have lost all of their sag....yeah they are shot as well. The oem spring rate is .90kg/mm and what these bikes need is a spring rate of 1.2kg/mm. And while you have the forks out to change the fluid, you should go ahead and replace the springs. The most convenient thing to do would be to use Progressive brand springs (which are a multiple spring rate) but most experts say you really need a constant rate 1.2 kg/mm spring that you can get from Race Tech, Sonic Springs (which I reccommend) and several other suppliers. But this is not an easy task which will take most of a day to complete. You have to pull the fairing off and suspend it in order to get the forks out to drain, etc. Hope this helps, Rick I have a set of springs (and cartridge emulators) to install on a friend's RSV later this year, so maybe I'll go ahead and work up a detailed set of instructions?
elmicko Posted October 26, 2011 #8 Posted October 26, 2011 For what it's worth, I replaced my front springs with Progressives this summer along with 10 wt fork oil and I'm VERY happy with the results. Mine is an '03 and it was diving a bit under breaking and "floating" after going across a good bump before the change. All is good now.
RedRider Posted October 26, 2011 #9 Posted October 26, 2011 Kreg, What you describe is a classic (compression/rebound) dampening issue. In other words your oil has turned the consistency of water and is shot. It is also a 7.5 wt which is very thin.....the same weight that a sport bike with cartridge forks requires. It needs at least a 10wt. And I will suggest that the bottom of your forks are filled with a black sludge? But when you talk about the front end diving a bunch, your issue is that the springs have lost all of their sag....yeah they are shot as well. The oem spring rate is .90kg/mm and what these bikes need is a spring rate of 1.2kg/mm. And while you have the forks out to change the fluid, you should go ahead and replace the springs. The most convenient thing to do would be to use Progressive brand springs (which are a multiple spring rate) but most experts say you really need a constant rate 1.2 kg/mm spring that you can get from Race Tech, Sonic Springs (which I reccommend) and several other suppliers. But this is not an easy task which will take most of a day to complete. You have to pull the fairing off and suspend it in order to get the forks out to drain, etc. Hope this helps, Rick I have a set of springs (and cartridge emulators) to install on a friend's RSV later this year, so maybe I'll go ahead and work up a detailed set of instructions? Rick, I am very interested at seeing this set of instructions. Will be upgrading the springs this winter as they are getting pretty weak (or maybe I am just gaining weight - Naaahh!). RR
allwx Posted October 26, 2011 #10 Posted October 26, 2011 I changed out my fork oil two months ago. I went to 15W oil (Honda brand) and did not notice significant change in damping as a result. I considered replacing the springs at that time, but decided against it because the bike had only 22k miles on it, and I've been happy enough with the action of the forks as they came from the factory. Next time I do this I will install new springs, just 'cause. I had a helluva time getting the fork caps back on. My 62 y/o hands aren't what they used to be, and I didn't have a helper. So... I ended up making a tool out of a chunk of wood. I chiseled out a space in the woodblock for the air housing on the cap such that I could apply strong pressure to the cap as I turned it clockwise, the air housing acting as a hold point for the block. I used the bike's lower bracket as a vise, since my puny little chinese vise wasn't up to the job. One critical step under these conditions was to index the cap threads with the forktube threads before starting. With the bike chassis in the way, there's only about 60 degrees of rotation available. Therefore, the threads have to engage almost immediately. The indexing obviously has to be done prior to mounting the forktube into the lower bracket, with spring out. Find where the threads first engage, then make a feltpen mark on both cap and tube to find the spot. Start at that aligned spot, push the cap down onto the spring, turn the cap carefully so as not to crossthread, and that's the job. Next time I do this I will burn a lot fewer calories.
wes0778 Posted October 26, 2011 #11 Posted October 26, 2011 Thanks Rick, that helped alot.. I kinda figured that after 10+ years that they are shot, but knowing what a job it is going to be, thought I would ask. gonna be a Dec. job. for sure. Thanks again. DECEMBER????? Heck I thought you were gonna learn all the "gotchas", pretty quick, so I could bring my bike out there and you could change the oil in it!!!
jer878 Posted October 27, 2011 #12 Posted October 27, 2011 I replaced the stock fork springs with "Sonic Springs" 1.2's and it improved the ride greatly. Also changed the oil.
Kregerdoodle Posted October 27, 2011 Author #13 Posted October 27, 2011 well, bring it Walt, and we can have them both tore up at the same time!! I just don`t want to mess up any riding weather should it take more then a day to do, but want to have it done before RockPort.. Kreg DECEMBER????? Heck I thought you were gonna learn all the "gotchas", pretty quick, so I could bring my bike out there and you could change the oil in it!!!
Squidley Posted October 27, 2011 #14 Posted October 27, 2011 Let me know when you want to do it Doodle and I'll help you destro....I mean upgrade it
Kregerdoodle Posted October 27, 2011 Author #15 Posted October 27, 2011 LOL will do...may need to get Gumbo and his BIG hammer as well, gonna order the springs in a few weeks.. what all do I need to get???? Let me know when you want to do it Doodle and I'll help you destro....I mean upgrade it
wes0778 Posted October 28, 2011 #16 Posted October 28, 2011 LOL will do...may need to get Gumbo and his BIG hammer as well, gonna order the springs in a few weeks.. what all do I need to get???? Let me know when, I may just pester some of you for a bunk so we can change the oil in mine. AND if past history is any indication I'll need Thor's hammer!!!
Kregerdoodle Posted October 28, 2011 Author #17 Posted October 28, 2011 will do Walt, try and give ya a week or so heads up.... I have room for ya. Kreg Let me know when, I may just pester some of you for a bunk so we can change the oil in mine. AND if past history is any indication I'll need Thor's hammer!!!
