Thanks for the response, my AIS has been disabled. Would I be better off to plug all four ports. I have two plugged now. Will I need to sync again if I plug all four?
Thanks
Richard
I did mine and it made the idle rougher and when i resynched the carbs 3 months later due to surgng the synch was way off. i plugged them back up and all is fine. No difference in milage though.
Thanks
Richard
Yes, you should plug all four. Shouldn't affect the sync at all but being as it takes about 10 minutes to sync them, you may as well check them anyway.
