midnight maddog Posted October 12, 2011 #1 Posted October 12, 2011 Has anybody tried to polish the RSV front rotors ,after removing the chrome covers, for a different look . Maybe sand ,polish, and clearcoat 'em. Or will they just rust? David
Guest Posted October 12, 2011 #2 Posted October 12, 2011 http://www.sloneservices.com/metric-magic/images/polished%20rear%20rotor2.jpg YEP!!! http://www.metric-magic.com/ Tim at Metric Magic does polishing. I plan on doing my rotors myself next week.
Flyinfool Posted October 12, 2011 #3 Posted October 12, 2011 Now I would think that a polished surface on the part of the rotors that the brake pads run would reduce your stopping power until the pads get them worn back to the correct finish. Which will mess up all of that work you put into polishing them. I would certainly NOT clear coat them or you may have no brakes at all till the clear wears off. I would almost think that polished rotors would be more for a garage or trailer queen so that the brakes do not get used to mess up the polishing. This is all just a guess on my part.
midnight maddog Posted October 12, 2011 Author #4 Posted October 12, 2011 Not talking about clearcoating where the pads contact, just the center. Those look like what I'm talking about, Ruffy. What about the clearcoat? David
Moped Posted October 12, 2011 #5 Posted October 12, 2011 You can polish the rotors to look plated. Like stated before no need to polish pad area as it will dull right now. It will still brake fine. Being stainless they will polish just fine, hold the shine, and no clear coat. Clear coat can be used on aluminum, copper, brass, etc. where oxidation occurs. Unless industrial clear is used standard laquer or poly will turn yellow tint and peel over time. Polishing is labor intensive (not talking shoes) especially on stainless. You have to sand them glass smooth and then I would recommend a 3/4 HP or better buffer, sissal wheel and green bar (stainless) compound. Also, wear a mask.
Guest Posted October 12, 2011 #6 Posted October 12, 2011 Yea , what moped said. A good caranuba wax should give you decent protection vs a clear coat. I dont plan on polishing the pad area but the center hub and the rotor edge.
