I purchased my 89VR (26500 miles now) a little over a year ago and the previous owner said the cruise control was made inoperable at the shop because he heard of a friend that got in an accident due to using the cruise control, so he said. I have no reason not to believe the reason. I would like to make it useable again. I share this thinking that one may proceed in a different manor than if it just malfunctioned. Your suggestions would be helpful if I could receive help from the simple to the more complex.
On the road I press the cruise button on and it lights up green. Then I set the cruise and nothing. I have used the cruise on a 91VR, so I have some operation knowledge.
Suggestions welcome.
Thanks.
I have the same issue lights up green and nothing. Dingy printed up a very nice wiring diagram. In the tech section. Thats where im going to start. Lots of systems will make the cruise not function
I'll be watching this thread with great interest...as my cruise doesn't work either.
But I think I know where to begin to look.
It will only start when in neutral...so I believe I have an issue with my clutch switch.
My '84 gave me grief for a while when I got it. I could turn on the criuse and get the light. I'd slide the switch forward and get nothing. This was always on the highway.
One day I was out at the park and roaming the roads there. Only rolling about 30 or 35 mph. I hit the switch and went to set the speed and it locked in. Great! But as I tried to do this at higher speeds it failed to set.
I figured out the levers were so worn that when I was moving faster the levers were pushed back by wind pressure and it was kicking off the cruise. If I held the levers out with my fingers it worked fine at any speed. Awkward....hell yea!!!
I made some plastic shims to try and it worked ok until they worked loose. I have not got around to making a decent long lasting repair.
Something to cheack anyway.
Mike
