dacheedah Posted September 25, 2011 #1 Posted September 25, 2011 When I look at the turn signals on the front, they stay lit all the time and flash for turn signals, the rear only flash for turn signals. Looking to add more light to the back, has anyone tried mounting front turn bodies on the rear and wired them as running and turn signals?
eusa1 Posted September 25, 2011 #2 Posted September 25, 2011 Easy enough to do, but you would have to run a red lense to be legal in illinios
dacheedah Posted September 25, 2011 Author #3 Posted September 25, 2011 My bike came with red lenses in the rear and I haven't tried it but they look the same.
Guest medicman91681 Posted September 25, 2011 #4 Posted September 25, 2011 I went the extra mile, I "gutted" the rear housings and went to Auto Zone, bought 2 1157 dual filament bulb sockets, ran the extra wire, tied one into the rear brake running light and the other is my blinker. Had to do alot of modification to the socket, i.e soilder a ground wire to the socket, cut it down to fit in the original rubber gasket that holds the factory socket, so you see it got alittle complicated but I absolutly love it. It took me somewhere in the neighborhood of 6-7 hours to complete but it was totally worth it. I know the site rules of having pictures and I wished I would have taken some but it was very tedious. Hope this helps you out some.
farm1810 Posted September 25, 2011 #5 Posted September 25, 2011 If I choose to do this, can I pull the wire out enough by loosening the light fixture clamp, then pull through some extra wire. Then, attach the two wires from the front fixtures to the one orginal rear using the one to pull through / in the two new wires? Or, do I need to remove the rear tire to get enough access to feed the two wires? I assume the junction of the rear turn signals, brake light, parking lights is behind the license plate? Is that right?
jrsain Posted September 26, 2011 #6 Posted September 26, 2011 dacheedah said: When I look at the turn signals on the front, they stay lit all the time and flash for turn signals, the rear only flash for turn signals. Looking to add more light to the back, has anyone tried mounting front turn bodies on the rear and wired them as running and turn signals? You may know of this mod, but it is a HD licence plate light bar and if you pick up the wiring out of the licence mount you will have two additional rear tail and brake lights. Ebay for $70
dacheedah Posted September 27, 2011 Author #7 Posted September 27, 2011 I had my 89 lit up like a Christmas tree, I have the Harley kit and led's for the rear and they should be here before the weekend. I also ordered passing lights for the front and thinking about replacing the reflectors with leds... sooo how many is too many
TheKid Posted September 27, 2011 #8 Posted September 27, 2011 dacheedah said: When I look at the turn signals on the front, they stay lit all the time and flash for turn signals, the rear only flash for turn signals. Looking to add more light to the back, has anyone tried mounting front turn bodies on the rear and wired them as running and turn signals? That would work but you def need to make sure you have red lenses or clear with red bulbs. I did what another person just did. I have the Custom Dynamic LED in all my turn signals. Rear are now run/turn/brake and I replaced the brake light with the orignal led board i think it is 48 led instead of 100. it is super bright. Call up CD they are great to work with www.customdynamics.com
Guest tx2sturgis Posted September 27, 2011 #9 Posted September 27, 2011 XV1100SE said: Can't figure out how to paste the thread address using this tablet but if you do a search for Custom Dynamics you'll see the thread I did on the install. Not to hijack the thread, but if that tablet is an iPad, maybe I can help with that.
dwatson636 Posted February 24, 2013 #10 Posted February 24, 2013 When I had my 82 XJ650, I changed the rear sockets to dual circuit ones and replace the bulbs from the 1156 to 1157. wired the extra wire to the license plate light. There was always issue with the XJ charging system. Very limited extra voltage. If I do this to my RSTD, do I have to worry about using too much power?
dingy Posted February 24, 2013 #11 Posted February 24, 2013 Somewhat similar thread linked below. I added tail light circuit to rear turn signal housings on a 1st gen. You can dye the lens using Rit clothes dye. I did it to the plastic lenses and they have held up for at least 3 years. http://www.venturerider.org/forum/showthread.php?t=47227 Gary
