What is the 'recommended' position of the E clip on the carb diaphragm needle valves? Needle valve is similar to one on bottom of attached picture, not exactly but close.
I am getting these carbs closer on Speedy, but I stil have a slight popping below 3,000 RPM's & gas mileage is somewhat lower than expected. About 25-30mpg range.
Carbs are 35mm mikunis with stock VMax jets in. 150 mains, 90 PAJ2, 170 PAJ1 & 37.5 pilot.
Gary
