goatturtle Posted September 19, 2011 #1 Posted September 19, 2011 Can anyone tell me if there is a difference in a tire marked front and one marked rear?
V7Goose Posted September 19, 2011 #2 Posted September 19, 2011 There is a difference. The tread pattern is usually a bit different. The direction of the tread grooves is reversed. The direction the belts on the carcase are overlapped is reversed. Often the same tire size is a lower weight rating for front tires. Goose
