Has anyone ever seen or used one of these trailers?
http://www.discount-trailers.com/motorcycle_trailer.htm
I've been thinking about either building or buying a 5x10 trailer. I saw this and it interests me because it would fit through my basement door (60" width) for storage. My concerns with the design are the relatively narrow track which may be mitigated by the low center of gravity. Also, I don't know how sturdy the trailer would be without a full frame. Would the diamond plate flex?
Just curious.
DT
Just two cents but I doubt the checker plate will flex as there many formed edges which would give it some strength.
Personally with the weight of our bikes I would like a trailer with a little more, in the axle and tire rating.
Nice little trailer though.
Brad
Dennis if I were you I would look into the trailer that Bildar has its about the same size and very light.It would probably fit in the basement as well.I use a 5x10 landscpe type trailer when I move from job to job behind my rv and can get 2 bikes on it at one time although it is a tight fit. I am sure bill will give you info on the trailer if you ask.Here is a link with pics of his trailer being unloaded.
http://www.venturerider.org/forum/showthread.php?t=16921
Jeff
Just curious.
DT
I've seen these in person http://www.kendontrailers.com/ and they seem very well built and I like the fold up storability. I'm holding out for an enclosed within the next 5 years.
Jay
Guest KitCarson
Does that girl come with the trailer?? Who cares if the trailer flexes.....just throw the trailer away and keep the girl:rotfl::rotfl::rotfl::rotfl::rotfl:
I know now that I am truly getting old. Didn't see the girl. Had to go back and look again. :(
As for the trailer, I think it looks pretty nice. Looks to be pretty well built.
Did you guys download the assembly instructions? One of my big concerns is the number of bolts that it takes to put it together with. Would you have to go over the thing before every use and check the torque on all of them?
And Don, I know you're getting old, so let me make this easy for you.... http://www.discount-trailers.com/images2/motorcycle-trailer-12.jpg
Dennis
Dennis
I didn't see her either, thanks for directing the way. She don't look to good though, I doubt whether she can ride, doesn't look like she can cook, and she looks quite new so I really wonder if she's ever done floors. Maybe if I got her she could go out to get the mail, but then what would the dog do. Nah best leave her where she's at, don't look all that useful to me.
Guest KitCarson
Dennis
I would not worry about checking the torque on the bolts.....I have simply learned when dealing with bikes over the years.....either use loc-tite and loc-washers , or throw the supplied nuts away and go buy a box of ny-loc nuts and install those when you put something together, they will never come loose. Looks like a very nice trailer, but has only one purpose to haul the bike.......I like a simple landscape trailer a 5 by 10 can haul two bikes......do not remember where I got it......but bought this pre-made metal rail you bolt down to the landscape trailer , has a channel you run the tires into and a front wheel chock built into the front, I did not actually bolt it down, used large tractor pins.....re drilled the pin holes to fit and took the play out of the pins......can simply remove the channel and use the trailer for other things also....is kinda a pain putting the clips into the pins have to reach under the trailer and stand on your head ......Kit
I'd like to see a video of this trailer with a big bike being loaded because I don't see where you put your feet when the bike is on the trailer and it's a LONG way down to the ground. In the pics with the big bikes, it looks like the floorboards are wider than the trailer itself.
Just a concern.
Other than that, it appears to be an excellent trailer for a motorcycle. Just make sure you have it shipped to a business and save yourself 100 bux in shipping costs.
