2nd gen side bag help
If you install the guards that go on top of the bags, maybe you could utilize the mounting hardware on the inside of the lid?
But the stick on Velcro may still be the answer, but you may have to get an industrial strength version.
See this link below and review the differences in the adhesives I copied off their site. the Adhesive 0174 looks the best to me, but may be hard to find.
http://www.hookandloop.com/site/product_definitions.cfm
Try this link to McMaster Carr also and search for this catalog number 94985K811
http://www.mcmaster.com
Adhesives
  • PRESSURE SENSITIVE (PS) - The adhesive type of VELCRO ® brand tape which has a peel-off backing. The tape is also sold under the STICKY BACK ® Brand name.
  • Adhesive 0172 - An acrylic PS adhesive used in most applications. This adhesive is the standard that comes on most tapes and has RED logos printed on the peel-off tape.
  • Adhesive 0115 - An olefin based PS adhesive with high strength but low temperature applications, and has BLUE logos printed on the peel-off tape.
  • Adhesive 0174 - A new high performance PS adhesive for use in high temperature and outdoor applications. Limited availability.
  • 0140PRECOAT - This "dry" adhesive is pre-coated on the tape for later activation by ultrasonic sealing or with a solvent such as acetone. This is the tape to use in conjunction with liquid adhesive for a most secure bond.
Edited by M61A1MECH
spelling corrections
