Royalstarr Posted September 12, 2011 #1 Posted September 12, 2011 I am about to install a radio/amp on my '06 RSTD. I know I can wire the amp directly to the battery leads however i would prefer to have the radio controlled by the ignition switch. I'm looking for how to instructions. Any help would be much appreciated.
geep Posted September 12, 2011 #2 Posted September 12, 2011 There should be a switched plug in located under the seat, white plastic, just push the tinned bare wires into it
geep Posted September 12, 2011 #3 Posted September 12, 2011 Royalstarr said: I am about to install a radio/amp on my '06 RSTD. I know I can wire the amp directly to the battery leads however i would prefer to have the radio controlled by the ignition switch. I'm looking for how to instructions. Any help would be much appreciated. What kinda radio and how and where?
Royalstarr Posted September 12, 2011 Author #4 Posted September 12, 2011 Thanks Geep It is a Shark radio. I saw the plug under the seat near the battery but i thought the white plastic was a cap. i tried to remove it but obviously could not. do you need to pierce the plastic first before inserting the wires? and are the wires held in place somehow or do i need to crimp them?
geep Posted September 12, 2011 #5 Posted September 12, 2011 Royalstarr said: Thanks Geep It is a Shark radio. I saw the plug under the seat near the battery but i thought the white plastic was a cap. i tried to remove it but obviously could not. do you need to pierce the plastic first before inserting the wires? and are the wires held in place somehow or do i need to crimp them? I pulled out a male cover which exposed two round female openings, there is something inside there that grips the wires...kinda Mickey mouse but way better than nothing IMO
helmet012001 Posted March 9, 2015 #6 Posted March 9, 2015 Hey.. I"m doing the same on my 06 RSTD.. Did the switch under the seat work for you? I'm looking for an ignition wire too with not very good luck..... please help.. Wes.
