easternrider Posted September 11, 2011 #1 Posted September 11, 2011 I have had an ongoing problem with my 84 VR. On start-up, it continually smokes black, and then when riding/cruising, keep getting small snaps from the breather box. From what I have seen, it backs up on two cylinders. Anyway, today I took my laser temp gun and checked all outlets to make sure I was getting a good reading. They all showed between 72 and 78 F. Started the bike up, and let it get warm. Just at idle, the two front cylinders were showing 180 - 190 F, and the two back ones were 84 -85 F. Does anyone have any good / bright ideas?
friesman Posted September 11, 2011 #2 Posted September 11, 2011 It does kinda look like youre not getting spark on the back. I wonder if its the coils that fire the back. Does it get more even if you leave it run at a higher rpm for a bit? Ive heard some weak coils may not run right at idle...but its all just a guess until an expert happens along... Brian
Venturous Randy Posted September 12, 2011 #3 Posted September 12, 2011 What does it do when you unplug the back sparkplugs when it is running? RandyA
easternrider Posted September 12, 2011 Author #4 Posted September 12, 2011 #1 cylinder unplugged bogs the bike down and almost stalled, and the #3 bogs it down also, but not as noticable. Last night, I ran it hard, and checked the temp, all was good. The #3 was reading 392 F (not sure if that is a normal temp). While it was idling, you could see the temp dropping on the gun. Within a Min, the temp had dropped to 130F
Condor Posted September 12, 2011 #5 Posted September 12, 2011 easternrider said: #1 cylinder unplugged bogs the bike down and almost stalled, and the #3 bogs it down also, but not as noticable. Last night, I ran it hard, and checked the temp, all was good. The #3 was reading 392 F (not sure if that is a normal temp). While it was idling, you could see the temp dropping on the gun. Within a Min, the temp had dropped to 130F Sounds like a couple of plugged idle jets.... Have you adjusted the needles lately??
easternrider Posted September 12, 2011 Author #6 Posted September 12, 2011 Haven't touched the needles, but am in the market for some pilot jets. Next, may check the floats. Seem to have good spark........running out of options.......
