I have an 05 venture. When I set the clock to the correct time and turn the ignition switch off the clock resets to 1:00. It has never done this before. Any suggestions how to correct this?
Thanks,
  ACE50 said:
Clock! what clock, where is it? I read something that says Ventures have one but haven't seen one! What am I missing?
Ace
Hold down both buttons where you change your trip meter the clock will come up.
Mike
  XV1100SE said:
NP.
Like radio station presets it is one of those things I have to look up myself when I disconnect the battery and have to reset them.
My local O'Reilly's Auto filled me in on how to avoid the clock/radio resetting when changing batteries. Hook up another battery with jumper cables (or a battery charger) to the battery cables. Disconnect the battery cables, change battery, reconnect cables, remove other battery.
I did this on my wife's truck using the jumper points (seperate clamping locations for connecting jumper cables) and it worked great.
RR
A 9 volt battery on a cig lighter plug with the key left turned on while the battery is changed works as well. Just remember, tip is positive on the cig lighter plug.
  MikeWa said:
Ace
Mike
Just hold down the "select" button for at least 2 seconds to bring up the clock. Hold down both "select" and "reset" buttons for at least 2 seconds to set or reset the clock. So simple a caveman can do it!!
Thanks for the help. I had a blown 5 amp fuse located in the cowling and like V7goose said the backup fuse at the left side cover was blown.
Sure is a good thing that we have goose to take care of all of our concerns...we are gunna need a new section in the site called. "ask goose"
