I believe my CMS (computer monitoring system?) is damaged. Has anyone attempted a repair of the board or logic chips? I have an '89 VR and have had it for 3 years. It had a sealed battery when I got it and I know about the "resistor Mod" for the "Battery Level Warning". When I read about the Mod--I looked at my bike and saw that the probe was removed and wired into the fuse box. Mod done--right? I have recently addressed the issue of a weak charging system and shortly after solving that issue--my Battery Warning came on. I looked closer at the probe Mod and realized there was no resistor installed! I immediately installed one--then another---then a 100K "pot" in an attempt to satisfy the CMS. With the pot--I was able to try voltages as low as 2.2V with no success. I traced the rest of the circuit to the connector at the board, but all was good. I took the CMS apart looking for any obvious damage (blown caps--etc.), but all looks perfect. Despite this, I believe something within the CMS must have been damaged. I decided to unplug the red "LED" until I can fix it properly. Any help would be greatly appreciated--Shawn
Yes, the chip needs the resistor inline as a current limiting device, without it, that part of the chip is history. If you burnt it out, it is no big deal to change. The chip is a TD62504P I ordered 1 from local electronic shop. There are two on the computer board The battery sensor connects to pin 1 on one of the chips. That is the one to change. another tip is to install a chip socket on the board. If you blow it again in is just a matter of prying out the chip and pressing in a new one.
Thanks for the advise! All the solder joints look perfect--so I believe it is a chip /resistor/ diode (the most modern thing I've fixed is a point-to-point tube amp and some crystal microphones!). Skydoc--I will P.M. you with regards to your spare, but I may have to add your name to the title (half the parts are yours!). I would like to also pursue the chip replacement--thanks for the great advise there too.
You need 6-8 volts on the wire to turn off the low battery alarm. On my 83, I used a 1K ohm resistor, but on my 89 I went a bit higher, I think about 15K. If I went above that, the alarm came on.
Frank D.
  • 1 month later...
I checked Digi-Key, Mouser, and Newark, none of them have this chip.
For those so inclined to find us a substitute IC, here is the data sheet for the TD62504P.
I did find the chip here thru Google but I know nothing about this company.
Hey Shawn,
When you guys refer to a "pot", are you taling about a potentiometer??
  • 5 months later...
This appears to be another chip that would substitute- no guarantee http://www.mitsubishielectric-mesh.c.../m63803p_e.pdf
Lots available on google search, but all providers appear to be china or hong kong.
If the unit had been operating, with 12V applied, and No resistor Installed ---
The board is most likley " fried "
Eaisest, and cheapest fix, is to try to find another Instrument panel from a salvage bike. Swap the boards.
Also, you will end up with an extra set of Speedometer, and Tach, if in future you need them.
Just another thought.
If you have the ability to replace this chip, then you would also have the ability to add the resistor on the circuit board from pin 1 to a +12V circuit run to make it a permanent fix.
Hmmmmmm........
What if while replacing the chip you cut the circuit run that goes from the connector to pin one and add in a 6.0V Zener diode so that it will not matter if the wire is used with the probe as designed or connected to +12V. Would it really be that easy?
