I have been working on my leaking clutch slave all summer. Made the mistake of "having" to have speed bleeders on my clutch slave. That lead to a sheared off bleeder screw, replacement of clutch slave entirely. Now I put on the new clutch slave with the bleeder screw that it came with and had a heck of a time getting the seal tight enough to draw fluid. With much help from here and plumbers tape I got a tight seal and and the clutch working. Now I have the same leak from around the bleeder valve. It can't be tightened anymore. So, how do I get the seal tight enough around this bleeder screw so that it doesn't leak? How do you bleed out the line losening and tightening and keep the seal tight enough when you are done? Can't believe I have to pull the cover, drain the oil, losen up the clutch slave just because they design these things that you can't unscrew the bleeder screw the hole way out. Crazy. Appreciate your help. Sorry for my attitude. It is the 4th time I will have the clutch slave off this summer.
Are you using the SpeedBleeder?? I had much the same problem with a new speed bleeder on my slave. Would not stop 'weeping'. Dropped Speed an email and they replaced it imediately. While waiting for the replacement I used an old one I had laying around and it worked just fine... I use Speeds on all my bikes and this was the first one that had ever given me a problem...
