I have removed the right side oil seal, bearing and collar. I removed the drive pin assembly and oil seal on the left side. The bearing on the left side appears to be removed toward the right, is this correct and what do you use to drive it out. I have a Tusk bearing puller but this bearing cannot be remove toward the left due to burrs inside the wheel. The only way it could have been installed is through the right side.:think::think:
:farmer:
