Fuel Pump Change
Fuel pump died yesterday so did a change out today.
I went with the Mr. Gasket 42S model and the NAPA 3011 fuel filter.
Was a very easy job and cost less than $60 total. WAY better than the $213 price I found on line.
Only caveat I can give is to make sure you get the 90 degree, 45 Degree and the nipple and do not use the filter that comes with the pump. There is absolutely no way it will fit in there otherwise. Set it up like this picture
I cut the line from the original pump and just connected it to the new wires just to keep it cleaned up.
I also cut down the line from the filter to take the bend out and. I did not fasten down the new pump as it all tucked in fine just under the original mounting bracket.
Edited by AKRefugee
