I used to make them, but retired from it a few years back. I dont think anyone is making them these days, I might have to look into starting them up again as I have seen a few thread about folks wanting them.
Well, you can simply, Resolder Both Ends, of Both of the old cables.
You might find on carefull inspection, that the factory did not solder the studs, I found that on my new 89, back in 93 that two of the 4 studs had been Soldered.
The other 2 had not.
Simply, cleaning all 4 studs, ( dip in solder flux, and heat with torch ) and then Resolder all 4 studs, is a big improvement!! ( use rosin core solder )
Also where the Neg Cable is grounded to the Engine case, remove the bolt and clean up the corrosion.
Also, where the Pos. Cable Connects to the Starter Motor, you will most likly find Corrosion,
After, cleaning and resoldering the cable Studs, you will have a big Improvement.
Also, Your Starter Solinoid, if over 50K on the Bike, most lilkey is burned to a Crisp Internally !!. Replace the Solinoid, !! This will also be a big improvement in the speed at which your Starter Turns !!
( A DEKA, dry cell, battery is also highly reccomended !! ) Check with " Condor " on the Battery thing, he will back me up on that !!
Also, be sure to Check the Pos. Bat Cable below, the Left, fwd , corner of the battery box, as it pass's thru the frame. Might be some wear, or damage, on the cable insulation, there from rubbing on the frame.
Edited by GeorgeS
Thanks guys for the help, I just went ahead and made my own set! Different starter, new plug wires, and battery cable upgrade! Huge improvement. Big shout out to Dingy for selling me a starter, plus he is a walking repair manuel, Thanks again
