rod Posted August 26, 2011 #1 Posted August 26, 2011 If you have verizon and a Driod be advised they do not cover your phone with insuance. you have to have the extended warrantee and it is still a fight and you will loose. Pay every month for years (I started with Air Touch) The Droid Phone is designed to fail in 2 years. Be warned. Your insurance is no good unless you break it (hit it with a hammer if you have any problems) that is the only thing they cover. Once you try to have it fixed they screw you; again if you have any problem hit it with a hammer, they cover nothing other than that. I hope I have saved some of you some hassle I have had for the last 3 days. Back to a regular phone. Rod
