Mountaineer47 Posted August 25, 2011 #1 Posted August 25, 2011 I have a 2008 Venture. I am considering doing the Marshal Mod. The instructions refer to keeping the current two antenna set up. Can the AR-1A splitter be used to convert to a one antenna system on the 2nd generation Ventures?
etcswjoe Posted August 25, 2011 #2 Posted August 25, 2011 I have a 2008 Venture. I am considering doing the Marshal Mod. The instructions refer to keeping the current two antenna set up. Can the AR-1A splitter be used to convert to a one antenna system on the 2nd generation Ventures? Yes you can go single antenna using a splitter, just make sure the single one is a CB antenna.
Sideoftheroad Posted August 27, 2011 #3 Posted August 27, 2011 http://bludolphintravel.com/gmg/marshallmod.htm Just past 1/2 way down the page there is instructions on how to do the single antenna mod. Bummer is a good resource on how to do it too since that is how he has it setup.
