  • 2 weeks later...
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
Ok, the LEDs from Northern tool came in this afternoon.
As was mentioned the "bulbs" can be popped right right out of the stiff rubber housing. I had to cut the wires, but no big deal there. They fit right in the the passing light buckets. Took it for a quick spin and WOW they are bright!!! :cool10::cool10::cool10:
The down side now is the Silverstar Ultra is now what looks like an amber fog light:crying:
Guess I gotta punch up Canadian Cruiser Customs to see what they are gonna do about my (in warranty) failed HID. :stirthepot::stirthepot::stirthepot:
The next to last picture shows the difference between the new LED on the right of the picture to the stock incandescent on the left.
Edited by wes0778
SO Wes0778 can you do a check on the radio and comms to let us know if your getting the interfearence that has been reported ocasionaly?
The specs for the lights off Northerns site says the lights are something like 3.79 inch or something. They fit right in the RSV light bar?
Haven't used the CB to check it, but the FM radio played just fine on my commute to work this morning. Don't know what they are measuring, but when you remove the "bulb" from the housing, it is the exact same diameter as the sealed beam bulbs, and fit's perfectly in the RSV buckets.
Wes....I just ordered those lights from Northern Tool. One step closer now to having passing lights on my Venture!:cool10:
Boomer....who sez even de pygmies are excited about this...:whistling:
If you haven't yet, set up a relay and draw Headlamp power direct from the battery, it will brighten the HL and make it look more like the LED passing lamps. Passing light power from the battery will brighten them also. I have Wagner 4449 sealed beams in both RSV's, one setup with the relay (01), one not (08), the one drawing from the battery looks bright white while the other looks yellow. Both are running Silverstar Ultras and the 01 PL's look to be the same color.
The next to last picture shows the difference between the new LED on the left of the picture to the stock incandescent on the left.
Thanks!!! But I've had a relay on the headlight almost from the time I got the RSV. The Silverstar Ultra did look "bright white" next to the stock passing light(also on their own relay) bulbs.
  Cougar said:
Now what to do with all these left over rubber LED light holders :think:
might be a good coffee cup.. plug the hole :confused24:
You could put your headset speakers in them, a little duct tape to hold them on your ears :thumbsup2: A quiet ride and great acoustics :cool10:
Hey Gang.... these lights just went on SALE today for $34.95 each... I called them
and they refunded me 10 bucks .. they have a 30 day thing on that in case
you have ordered them in the last month or so.. Mine should be here Friday .
Jeff
Calprin: what housings are you using. I am looking to change mine out from sealed beam to a seperate bulb type. I think the star part number I have found that might be correct for the housing is STR-4wm35-50-ea. I have been trying to source some from a Harley also on e-bay. But so far the take offs I have found they guy wants me to make this months payments for him.
These are a perfect fit and seem much brighter.
The LED is already in the OEM Ring for the light bar.
The Middle is the OEM Light.
Thanks for the tip.
[ATTACH]65904[/ATTACH]
[ATTACH]65905[/ATTACH]
[ATTACH]65906[/ATTACH]
These are on sale in the stores @ 34.95 until 4/28. There are coupons that just came out in a direct mailer that will get you $5 off $15. IE: 29.95ea + Tax.
For those that live near a store that is....
(Not saying where I work -lol)
  Cougar said:
I have never seen a Northern Tool Retail Store in my life any place.
must be a top secrect thing I guess :icon_smile_question
There are 75 Northern Tool Stores. Go to NorthernTool.com for store locations.
Boomer....who sez they do not admit pygmies into their stores....:whistling:
  • 1 month later...
Got mine installed in about 45 mins yesterday. WOW, what a difference. NOW gotta give the headlight bulb the boot in favor of something close to the new DL's.
Is the HID the way to go or Ultrastar?
