I need some help. I am trying to diagnose a problem that just developed with out having to tear the engine apart looking for something that I don't know what I am looking for.
Yesterday, I was on the freeway going about fifty to sixty mph, getting up to speed. While at that speed, I heard a sound that SEEMS to be coming from the clutch and/or water pump area. It kind of sounds like loose metal rattling around. Pretty loud. Maybe a sound that it would make if it was starving of coolant or oil. When I get up to 70 mph, it seems to stop, although I can't tell if I just can't hear it because of the wind.
This morning I took her out and the sound goes away when I pull in the clutch. But while the clutch is disengaged, if I rev the engine I still hear the noise. I hear no noise at all when it is idling in the driveway or going slowly. It shifts gears fine.
I'm thinking it could be a water or oil pump issue and/or a clutch issue. I just don't know.
I know I probably haven't given you enough to go on yet... but any ideas or things that I can check would be GREATLY appreciated!!!!!
1998 Royal Star TC XVZ13AT
I really thank you for your time and thoughts!!
Mike Rice
texasrices
If the water pump bearing is the cause of the noise, there is the possibility that the contact between the ceramic face seal and the carbibe lip in the water pump may allow oil & coolant to mix. This may not happen if the shaft does not deviate much from intended center line.
But if there is oil/coolant crossover, that would narrow it down quite a bit.
Gary
Get a mechanic's stethascope with a long probe and start checking out while riding or sitting still. It will isolate the location for you.
:farmer:
A large screw driver will work just as well..... :)
With a stick of wood as a probe, I placed it on the clutch housing and the water pump housing. When I pulled on the clutch, I only heard a slight change in the sound. But nothing like loose metal rattling around in there.
I may have to go get a mechanics stethoscope tomorrow and try to really narrow it down better.
Wood does not transmit sound well. A screwdriver with a hard plastic handle is the better choice if you do not have a mechanic's stethoscope, but it is still nowhere near as sensitive. When you are using a real stethoscope, be careful to not accidentally knock the probe against stuff - the sound will be VERY loud in your ears!
Goose
:farmer:
Just a thought here, but wouldn't using a stethoscope to study engine sounds while riding possibly lead to the sound of crushing metal and breaking plastic?
Andy
Well, I guess it is time to start taking things apart and see what I can find. I will update with results. Meanwhile keep the ideas coming.
Thanks y'all
:fingers-crossed-emo
I got a stethoscope and probed around. I did'nt really hear any strange clunking or clattering anywhere. (but I'm no mechanic.)
What I did find is oil in the coolant resevoir. I would tend to think that this is a water pump oil seal according to my research as well as a post from BigBear back in April 2011.
I also drained the oil but found no coolant in there.
Does that explain the noise that I was hearing though?? Like metal dragging on the right side of the engine. Or maybe a sound that a loose baffle could make???
Still working
Certainly sounds like you have a water pump problem to me. A small oil leak into the coolant will turn to foam and be blown into the overflow.
Goose
Goose
Bodda Bing, Bodda Boom...I think you got it Goose.
:farmer:
And also the 3rd post in response to your problem on 8/19/11.
:think:
Gary
My granddaughter just had the same problem with her Chevy, and the engine was blown, a head gasket was blown, fix it quick before there is more damage eh?? Hate to see you lose the engine on that. Her car is now scrap due to the fact that there are no 3.1 engines available in scrapyards in Michigan. It seems the cash for clunkers used up all the scrapyard gems around here.
Well I replaced all the parts in the water pump today. Seals, o-rings etc. Fired her up to check for leaks and found none. At this point I'm pretty proud of myself.
I take her out for a test ride and the sound is still there.
So.....
Is there anyone around the Dickinson/Clear Lake Texas area that can and or would recommend a reputable repair shop?? Obviously the local stealer is OUT of the question since I haven't won the lottery yet.
Hey...without hearing or being able to touch your bike; it could be the timing chain or guides rattling around. Without load on the engine (cruising speed) it would be more prominent. If the noise disappears with the engine under load; a good chance it could be worn? As you said reving the engine with the clutch pulled in (not under load) you can hear it. Just a thought.
But then again I've been wrong before. :confused24:
