Bobby G Posted August 12, 2011 #1 Posted August 12, 2011 The wife bought me three 18" red LED light strips to mount on the RSV, which I'll probably mount under the tank rim so that they will light up the chrome in the engine area. Just not sure about what kind of on/off switch to get or the best place to mount it. Any suggestions?
Bubber Posted August 12, 2011 #2 Posted August 12, 2011 I suggest water proof rocker switch or rubber coated toggle switch. I have a Ponch gauge cluster in my dash instead of the cassette player and that is where I mounted mine. BTW I also have quick disconnects on the leads to the lights to make taking the tank off a lot easier. Just a thought.
BuddyRich Posted August 12, 2011 #3 Posted August 12, 2011 I put mine behind my seat on the left side. There's a piece of black filler there with plenty of room and your right next to the battery. I also have a couple of switches in the inner fairing. You'll have to drill a couple of holes to do that.
Guest Posted August 12, 2011 #4 Posted August 12, 2011 http://www.customdynamics.com/installationkit.htm Here ya go Bobby. My set-up came with waterproof rocker switches already, which Bubber referred to. The lock connectors in the kit work great too. Made wiring the bike much easier. I have my rocker switch double sided taped to the underside left side of the seat area, on that plastic shield, just within hand reach range. Kinda looks like im scratching my butt but it works for me.
REDRIDER52 Posted August 12, 2011 #5 Posted August 12, 2011 I have mounted a switch with dimmer on center pannel under seat also added switches top of brake resvior
Bobby G Posted August 14, 2011 Author #6 Posted August 14, 2011 Thanks for all of the great suggestions. I'll be switch hunting over the next few days, and will post pics when I get everything up and running.
Jethroish Posted August 15, 2011 #7 Posted August 15, 2011 I put mine behind my seat on the left side. There's a piece of black filler there with plenty of room and your right next to the battery. I also have a couple of switches in the inner fairing. You'll have to drill a couple of holes to do that. Put mine in the same spot.
Bobby G Posted August 24, 2011 Author #8 Posted August 24, 2011 Got the lights on and the switch mounted right where you did, in that little hole that's plugged for an add-on 12v adapter just behind the seat on the left. Perfect place for it. Was easy once I figured out how not to electrocute myself! Did a fast and dirty installation that I'll clean up a little with quick disconnect's and a better waterproof switch down the road, but for now, it really looks great.
