Just changed the rear tire and confused about the assembly of the spacers on the rear wheel. I read the posts on the tech pages about the spacers but I have a thick spacer not shown in those photos. I've highlighted it below. Where does it go? (I have the nut and washer for the other side)
http://i6.photobucket.com/albums/y217/gaillarry/VentureAxleSpacers-1.jpg
If it is indeed a 2006, there are only two washers one before and one after the "rear brake caliper bracket". And like you stated one washer and one nut for the axle.
:farmer:
Its a 2008, I can't type worth a crap. Its the spacer on the left of the brake bracket that has me confused. Does this look good now?
http://i6.photobucket.com/albums/y217/gaillarry/XVAxles.jpg
The inside spacer looks right as it is called a collar but the outside is but a washer between the brake braket and the swing arm.
:farmer:
FYI - your bike has a Barons lowering kit on it instead of the stock brake caliper bracket.
Goose
I was looking at that in the original pic and now the one above .... was wondering what the *&$! it was and moreover, what kindof bike as it sure don't look like what is normally there on these bikes.
Looking at the pic's again,that doesn't look like the same axcel thats on my 99 rsv???
ya ... mine don't stick out that far neither! :whistling:
