dingy Posted October 26, 2012 Author Posted October 26, 2012 Ignitech should have sent you a harness with the TCI. I don't have a picture of one that had the stock sensor wired into it. What info are you looking for specifically? Gary
jdog910 Posted October 26, 2012 Posted October 26, 2012 i cut off the plug off the original harness that plugs into the original CDI so i could hard wire it for troubleshooting, so i just need a pic of the connection between the original and the ignitech CDI there are a few pics on the site but not detailed enough.
jdog910 Posted October 26, 2012 Posted October 26, 2012 just like this but i need to see both sides of the connectors so i can see the wiring
dingy Posted October 27, 2012 Author Posted October 27, 2012 i cut off the plug off the original harness that plugs into the original CDI so i could hard wire it for troubleshooting, so i just need a pic of the connection between the original and the ignitech CDI there are a few pics on the site but not detailed enough. Thread below has detailed wiring schematics in it. http://www.venturerider.org/forum/showthread.php?t=42384 I also attached a PDF of TCI specific wiring. Look at lower half of page for your bike, which is a 4 pickup coil system. Then at some point read this thread. It helps. http://www.venturerider.org/forum/showthread.php?t=58880 Gary
dingy Posted October 27, 2012 Author Posted October 27, 2012 just like this but i need to see both sides of the connectors so i can see the wiring Here are a couple of pictures of the wiring harness side connector for a 4 pickup coil bike. Not sure what year these are from though, but I think they were 86~89 range. Gary
jdog910 Posted October 27, 2012 Posted October 27, 2012 fired right up! thanks again, does anyone have a tweekt program file that works great on the ignitech CDI that uses the stock boost sensor the "new version" that i just hooked up? All the ones I have seen are for the No boost sensor or the one with the GM sensor. BTW I have an 86 venture. thanks for the info on changing that.
dingy Posted November 1, 2012 Author Posted November 1, 2012 Will there be another group buy? I may see if there is enough interest after holidays are over. Would be completed while riding season is hibernating for us northerners. I need to get another one for the project bike. I have had several people say they were interested. I have found a 1/2 bar sensor that is much more compact than previous ones I got. Since it is a 1/2 bar, the response would be better than the 1 bar GM sensor. Gary
mralex714 Posted November 2, 2012 Posted November 2, 2012 I may see if there is enough interest after holidays are over. Would be completed while riding season is hibernating for us northerners. I need to get another one for the project bike. I have had several people say they were interested. I have found a 1/2 bar sensor that is much more compact than previous ones I got. Since it is a 1/2 bar, the response would be better than the 1 bar GM sensor. Gary Sorry to hear that. I was trying to get on the road within the next 2-3 weeks. I just got the bike and haven't ridden in a while and wanted to get in some riding in before I attempt Daytona in March.
RandyR Posted November 2, 2012 Posted November 2, 2012 Sorry to hear that. I was trying to get on the road within the next 2-3 weeks. I just got the bike and haven't ridden in a while and wanted to get in some riding in before I attempt Daytona in March. You can order an ignitech direct from the company yourself. As long as you've read this thread, everything you need to know is here.
icebrrg3rd Posted November 2, 2012 Posted November 2, 2012 ...I have found a 1/2 bar sensor that is much more compact than previous ones I got. Since it is a 1/2 bar, the response would be better than the 1 bar GM sensor. Gary Would that work better on the ones you sent out last group buy? Just wondering, as mine still has the occasional 4000 rpm cut-out and I am still trying to fix it. -Andrew
