1BigDog Posted December 11, 2007 #1 Posted December 11, 2007 Im going to order new passing light bulbs since im going to rewire the passing lights soon. I was also thinking about going to a led bulb. Since I am not disassembling it right now, I need to know what bulb size (type) is in there now so I can have it on hand. Thanks........
cowpuc Posted December 11, 2007 #2 Posted December 11, 2007 Sheesh Ruff,, you really had me going for a second there.. Due to the title of this thread I actually thought you had eaten some light bulbs and was having a hard time passing them... On the same token,, if that would have been the case it would have explained your screen name... 'Puc
1BigDog Posted December 11, 2007 Author #3 Posted December 11, 2007 Sheesh Ruff,, you really had me going for a second there.. Due to the title of this thread I actually thought you had eaten some light bulbs and was having a hard time passing them... On the same token,, if that would have been the case it would have explained your screen name... 'Puc Man, your killing me.....:rotf::rotf:
stardbog Posted December 11, 2007 #4 Posted December 11, 2007 Hey Jeff Check out this tread, there is LED replacement bulb for your passing lamps. Take off old bulb and find out witch bayonet base is ( H4, H3, H7, H11..ETC ) http://www.venturerider.org/forum/showthread.php?t=17108
1BigDog Posted December 11, 2007 Author #5 Posted December 11, 2007 Hey Jeff Check out this tread, there is LED replacement bulb for your passing lamps. Take off old bulb and find out witch bayonet base is ( H4, H3, H7, H11..ETC ) http://www.venturerider.org/forum/showthread.php?t=17108 Thats the thread that gave me the idea, but I was trying to find out which bulb was the proper one for the stock yamaha passing lamps without taking it apart. I want to order them and have them on hand when I do pull it apart.
1BigDog Posted December 13, 2007 Author #6 Posted December 13, 2007 Hmmmm, so like no one knows I guess........
dray Posted December 13, 2007 #7 Posted December 13, 2007 hey Jeff I'm not sure how your are but on my Vstar yamaha lights they just had eyelets with screws i cut them off and put on the female clips to slide over the spades no problem took me about 15 minutes to do both lights i went from stock to the H3's good luck Dray
Stoutman Posted December 13, 2007 #8 Posted December 13, 2007 There are two different configurations of passing lamps. The halogen configuration is a 35watt H3 bulb. I don't know what the other bulb is.
