DBOB Posted July 29, 2011 Posted July 29, 2011 Hi; I am putting a new rear tire on my 86VR. I have the repair manual and am following its' directions. I removed the 2 bolts from the caliper mount and am unable to remove the caliper. It rotates freely on the rotor when I spin the wheel but it will not lift off. Have I missed something? As ussual I apreciate any and all help
mbrood Posted July 29, 2011 Posted July 29, 2011 (edited) As the disc wears it will develop a lip on the outer edge where the brake pads don't engage and this is probably hanging your caliper, collapse the pads with a pry and it should slide right off. Edited July 30, 2011 by mbrood
Snaggletooth Posted July 30, 2011 Posted July 30, 2011 Crack the bleeder open a bit as you try to pry the pads back. It helps prevent any gunge from being forced back into the master also.
