In the highly unlikely event that you collide with something small in road and the sidestand switch is damaged,
cut the lead going into the switch. You will find two wires. Remove a little insulation and twist the wires together.
Just make sure the stand is up before you leave.
Didn't show up until I stopped for fuel. Put the stand down and the plunger must have stayed mashed, 'cause the bike wouldn't start in gear, only neutral. And died when I put it in gear. (Stand up or down) Switch must be jammed in open position.
